nycain Posted April 9, 2013 Report Share Posted April 9, 2013 hey guys just wondering my pusher fan never works ac on or nothttp://i1146.photobucket.com/albums/o538/nycain/IMG_20130408_102425-1.jpg Link to comment Share on other sites More sharing options...
tux Posted April 9, 2013 Report Share Posted April 9, 2013 jump the relay and see if it turns on Link to comment Share on other sites More sharing options...
nycain Posted April 9, 2013 Author Report Share Posted April 9, 2013 ok was thinking of doing that Link to comment Share on other sites More sharing options...
Shelby Posted April 9, 2013 Report Share Posted April 9, 2013 all fans have batt power to them directly,,they are turn'd on by controling the ground wires ,, test for batt power to the fan on both wires to the motor , both wires should show batt voltage with out fan runing ,, if not the fan morotr has an internal problem most likely brushes worn out,,,, now unplug the connector going to the fan motor,, note which wire has power,, replug the connector and jumper a ground wire to the wire that did not show power,,the fan should run , if it does go to the relays and check them and the a/c fan relay by the igniter on driver fender this relay bypass's the fan relays ( grounding close signal ) on the pass side fender,,but the passside fender relays MUST work Link to comment Share on other sites More sharing options...
