desert_starion Posted April 4, 2013 Author Report Share Posted April 4, 2013 sup desert, where you been hiding? Phil! whats up man, Im usually hiding at work, but I come out to play every once a while. Whats good with your car? Quote Link to comment Share on other sites More sharing options...
Funky Phil Posted April 4, 2013 Report Share Posted April 4, 2013 Nothin much, setups runnin good. Should see some 10's this year.Good to see you and the car still up and goin. Quote Link to comment Share on other sites More sharing options...
desert_starion Posted April 5, 2013 Author Report Share Posted April 5, 2013 Nothin much, setups runnin good. Should see some 10's this year.Good to see you and the car still up and goin. Yeah, I really need to upgrade the FIP firmwares on my ECU's to get the fuel and spark control using only 1 ecu, and then I should be more consistent. I hate that I am so busy to get some good tinkering done on the car which is why I want it to go to a good home. Nevertheless, it pulls hard. I havent been following up on what you have done to your car.. you got any links or threads I can read up to see your progress? Quote Link to comment Share on other sites More sharing options...
Funky Phil Posted April 5, 2013 Report Share Posted April 5, 2013 click my sig picture sir Quote Link to comment Share on other sites More sharing options...
desert_starion Posted April 7, 2013 Author Report Share Posted April 7, 2013 click my sig picture sir Wow look at you! took it to the next level. I wish I had the time to do the same. I have pretty much everything minus the R154 and a few other things. You did very good man I am glad to see your car doing good. Quote Link to comment Share on other sites More sharing options...
Xtreme Industries Posted April 8, 2013 Report Share Posted April 8, 2013 am i missing it or are your wipers removed? Quote Link to comment Share on other sites More sharing options...
desert_starion Posted April 8, 2013 Author Report Share Posted April 8, 2013 am i missing it or are your wipers removed? It was at the time, now Its back on Quote Link to comment Share on other sites More sharing options...
Xtreme Industries Posted April 9, 2013 Report Share Posted April 9, 2013 is all the original safety squipment still on the car and functional? any condensation in the lights, cracks etc..? does the heat and defrost work? i dont recall seeing AC, has everything been removed (including switching the interior duct to non ac)? how good is the paint? i see orange peel in pictures but not sure if it really as bad as it looks. are the door jams and trunk painted as well? what color is it? can the hood be replaced with factory hood (83 or regular) if need be or will it not fit anymore? how are the frame rails? does the antenae function correctly? Quote Link to comment Share on other sites More sharing options...
Xtreme Industries Posted April 9, 2013 Report Share Posted April 9, 2013 do you have any current pictures? Quote Link to comment Share on other sites More sharing options...
desert_starion Posted April 11, 2013 Author Report Share Posted April 11, 2013 (edited) is all the original safety squipment still on the car and functional? any condensation in the lights, cracks etc..? does the heat and defrost work? i dont recall seeing AC, has everything been removed (including switching the interior duct to non ac)? how good is the paint? i see orange peel in pictures but not sure if it really as bad as it looks. are the door jams and trunk painted as well? what color is it? can the hood be replaced with factory hood (83 or regular) if need be or will it not fit anymore? how are the frame rails? does the antenae function correctly? all the original safety squipment still on the car and functional? YESany condensation in the lights, cracks etc..? NO cracks or condensation and it rains alot in florida. does the heat and defrost work? Yes! i dont recall seeing AC,has everything been removed (including switching the interior duct to non ac)? Everything is attached, compressor leaks freon very slowly but its ice cold. how good is the paint? i see orange peel in pictures but not sure if it really as bad as it looks. are the door jams and trunk painted as well? what color is it?Paint is good, there are some chips/scratches, also it is bubbling in some areas (driver door) and it is cracking on the rear spoilers. Orange peel is because I never wet sand/ polish the car (final step) when the paint was done 3 years ago. If you wetsand/polish it will be as good as new. are the door jams and trunk painted as well? what color is it?Paint code is Octane blue (from 2008 EVO 8)- yes the door jams and trunk area is painted as well can the hood be replaced with factory hood (83 or regular) if need be or will it not fit anymore? how are the frame rails? does the antenae function correctly?The hood is just a stock hood with a 4" fiberglass cowl. The fiberglass is cracking where it meets the steel hood, and that is the nature of fiberglass when is bonded to steel it will eventually crack, it can be easily replaced with another hood of your choice. ( i may replace it soon )how are the frame rails?Frame Rails are solid, no rust ( original Arizona car)does the antenae function correctly?No the antenna is removed and replaced with a power antenna (installed on the roof where the rear windshield washer nozzle used to be) Edited April 11, 2013 by desert_starion Quote Link to comment Share on other sites More sharing options...
desert_starion Posted April 11, 2013 Author Report Share Posted April 11, 2013 do you have any current pictures? There is no difference between pictures on my flickr account and current way the car looks. everything looks exactly the the same, except the New turbo. Quote Link to comment Share on other sites More sharing options...
