idfaskpure Posted October 16, 2011 Report Share Posted October 16, 2011 Vacum Lines??? Theres a few vacum lines that are disconnected on my conquest. Theres one that runs from the vacum switch in the back left corner and one on the throttle body. The car runs and everything but id like to know where it all goes. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Indiana Posted October 17, 2011 Report Share Posted October 17, 2011 You'll need to give the year of your car, whether or not you have kept all the stock systems or not and then someone can answer. There's only a couple required hoses to drive the car and those are the wastegate actuator, the vacuum advance and the fuel pressure regulator. There's none that you can remove that will make the car run any better and could make it run worse and not pass emissions testing if you have those in your state. When they get removed it usually because they leak or are hooked up wrong. Quote Link to comment Share on other sites More sharing options...
idfaskpure Posted October 17, 2011 Author Report Share Posted October 17, 2011 Its a 1989 and yea it's all stock still Quote Link to comment Share on other sites More sharing options...
RF600 Posted October 18, 2011 Report Share Posted October 18, 2011 In the faq section there is the diagrams for the hose routing. Quote Link to comment Share on other sites More sharing options...
