Maddman200 Posted June 30, 2011 Report Share Posted June 30, 2011 my 89 conquest breaks up real bad around 9 pounds of boost and looses all power and the turbo shutters and surges, does this car come stock with a blow off valve or anything? im afraid the turbine shaft in the turbo is going to snap plus the vaccum lines are all messed up? motor runs great and the head gasket looks like it was just done befor i bought this baby? Link to comment Share on other sites More sharing options...
dmyers151 Posted June 30, 2011 Report Share Posted June 30, 2011 (edited) Monroe, NY? Am I reading that correct? This wouldn't happen to be a blue car with a flat hood? EDIT: I sent you a PM, hit me back, I can help you out. Edited June 30, 2011 by dmyers151 Link to comment Share on other sites More sharing options...
Frenchi934 Posted June 30, 2011 Report Share Posted June 30, 2011 There is no stock blow off valve on these cars. A very common upgrade is to splice a 1g bov/pipe into the softpipe right before the over the valve cover pipe. This should eliminate compressor surge. As far as vacuum lines go, there should be a diagram under the hood for routing, but if yours has been removed you can find one here: starquestgarage.com Link to comment Share on other sites More sharing options...
Shelby Posted July 1, 2011 Report Share Posted July 1, 2011 what he's describeing is not compressor surge,, sounds more like a boost leak in an ic pipe or hose two places are note'd for spliting the rubber 90 degree hose on the ic out port and the ovc pipe coupling, the 90 on the back side and the ovc hose on the bottom where you can't see them , also a clamp may look tight but under pressure they can slip back and alow air loss,, once the air is lost the air mass goes nuts and the ecu is lost so it shuts down Link to comment Share on other sites More sharing options...
Indiana Posted July 2, 2011 Report Share Posted July 2, 2011 or your vac. adv. is dead and it can't retard timing and its a misfire and the ignitor pulling timing back after it begins to knock. Have you tested your vac. adv.? Link to comment Share on other sites More sharing options...
Maddman200 Posted July 2, 2011 Author Report Share Posted July 2, 2011 replaced vac advance still same problem Link to comment Share on other sites More sharing options...
Indiana Posted July 2, 2011 Report Share Posted July 2, 2011 What spark plugs you using? Are they fouled? Your injectors been cleaned? How about the fuel filters? Link to comment Share on other sites More sharing options...
