twitch Posted May 2, 2011 Report Share Posted May 2, 2011 just picked up my new sq the other day it was running like complete garbage due to the valves being way too tight well ive fixed that and now it wont boost past like 3 psi i noticed there are two solenoids on the pass. side by the fire wall wnd there are a couple vacuum lines that are missing any help would b much appreciated or a pic would be awesome Link to comment Share on other sites More sharing options...
JAinsworth Posted May 2, 2011 Report Share Posted May 2, 2011 Look at the wastegate and see what is hooked up or capped off on it. Does the car have a manual boost control? If so, the soleniod is not needed.Jimmy Link to comment Share on other sites More sharing options...
twitch Posted May 2, 2011 Author Report Share Posted May 2, 2011 The only thing I can see on the wg is the line that runs to the ovc pipe and on the solenoid the top line is hooked up but Idk where the bottom goes Link to comment Share on other sites More sharing options...
Indiana Posted May 2, 2011 Report Share Posted May 2, 2011 Those things in the corner turn on the vacuum pump. They aren't related to boost control. The hoses or valve whatever you have if its not connected or wrong it won't limit or prevent boost lower than stock no matter how its messed up its the opposite you'll have way too much boost. There's something else wrong. Does it rev up if you floor it or just puke and want to stumble and you can't drive it like that? Link to comment Share on other sites More sharing options...
twitch Posted May 2, 2011 Author Report Share Posted May 2, 2011 it revs fine throughout the range just no boost Link to comment Share on other sites More sharing options...
twitch Posted May 2, 2011 Author Report Share Posted May 2, 2011 the gauge will go up to like 2 or 3 psi and just stops i am thinking the wastegat is open too far but idk how to check whether or not it is. should i b able to see threads on the actuator arm o and the car is 100% stock Link to comment Share on other sites More sharing options...
Indiana Posted May 2, 2011 Report Share Posted May 2, 2011 Stock gauge is useless, it doesn't use a pressure reference. How many threads on that rod who can say but if you remove it and put it up next to the pin it hooks on, it needs to be just a little bit short to reach, 1/8"-3/16" is all otherwise you can have boost surges as it is delayed in opening then slams shut and is hard to control and its not to get more boost its just to hold the flapper shut. How boost is controlled is what pressure effects the other end. http://www.b2600turbo.com/images/WGactuator.jpg Link to comment Share on other sites More sharing options...
twitch Posted May 2, 2011 Author Report Share Posted May 2, 2011 the boost isnt surging that i can tell and i cant feel anything as far as that goes it just kills me because i know its not running right i can floor it if im driving it it will take forever to go anywhere unless its in a low gear Link to comment Share on other sites More sharing options...
twitch Posted May 2, 2011 Author Report Share Posted May 2, 2011 is the line from the ovc pipe supposed to run to the wastegate? Link to comment Share on other sites More sharing options...
Indiana Posted May 2, 2011 Report Share Posted May 2, 2011 Yes but if this is hooked up wrong or not connected you'll have 30psi boost at least and if it is hooked up you'll still end up with about 10 or so. There's something else wrong like clogged up exhaust or the turbo is dead, the timing is way off or your secondary injector isn't working well. Link to comment Share on other sites More sharing options...
twitch Posted May 3, 2011 Author Report Share Posted May 3, 2011 Thanks for all the help guys my old man told me to check the cat and that's what it was haha Link to comment Share on other sites More sharing options...
