19cturbo Posted October 29, 2010 Report Share Posted October 29, 2010 in the back left corner by the wiper motor.. they are like little solenoids that plug in, what are they? what do they go to? can i remove them? http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs919.snc4/73271_1493230739829_1505850213_31216977_5630033_n.jpg thanks mike. Link to comment Share on other sites More sharing options...
ucw458 Posted October 29, 2010 Report Share Posted October 29, 2010 vac switch and relay for cruise control vac pump. Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2010 Author Report Share Posted October 29, 2010 vac switch and relay for cruise control vac pump. so with no cruise, you dont need them correct? lol thanks man.. Link to comment Share on other sites More sharing options...
ucw458 Posted October 29, 2010 Report Share Posted October 29, 2010 (edited) nope, only needed for cruise control. remove them. You can also remove that pump over the right side of the IC. That's the vac pump for the cruise control. Edited October 29, 2010 by ucw458 Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2010 Author Report Share Posted October 29, 2010 nope, only needed for cruise control. remove them. welp away they will go!!! lol Link to comment Share on other sites More sharing options...
InvolvedRotary Posted October 29, 2010 Report Share Posted October 29, 2010 If you follow the vac hose from them they eventually end at, what I can only describe, as either an air compressor or a vacuum thingy... Ive personally removed them both since they are part of the actuation of the cruise control setup. http://i21.photobucket.com/albums/b287/RX-7-88/Mobile%20Uploads/Photo10151610.jpg Though I have to say, you're strap for the Optima is very nice. Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2010 Author Report Share Posted October 29, 2010 has anyone who has removed the vac pump if your vents "float" or "Free flow". and the strap is home made, from a stop sign my buddy had..lol.. Link to comment Share on other sites More sharing options...
87starcar Posted October 29, 2010 Report Share Posted October 29, 2010 i have all of that stuff off of mine. the vents do seem to always blow a little bit of air at whatever you have it on, cool or hot. Link to comment Share on other sites More sharing options...
ucw458 Posted October 29, 2010 Report Share Posted October 29, 2010 If you follow the diagram the vac pump is only for the cruise control. When plumbed correctly there is a check valve that isolates the entire cruise system. The vac pump should not be connected to the canister. The white connectors are check valves. One to isolate the AC and one to isolate the cruise. Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2010 Author Report Share Posted October 29, 2010 i have all of that stuff off of mine. the vents do seem to always blow a little bit of air at whatever you have it on, cool or hot. did you leave the black canister? the one beside the power steering resivor? or did you remove it too.. Link to comment Share on other sites More sharing options...
InvolvedRotary Posted October 29, 2010 Report Share Posted October 29, 2010 I think it a decent trade off really. Lose more junk under the hood, and just set the vents to something on the warmish side. The air doesnt really go through all the venting, just whatever you have the controls set to. In my car I generally leave the vents to the floor open and the temp on 90 and the fan off, this way when the windows are down and im out and about in sandals my feet dont get cold as the hot air gently blows. Link to comment Share on other sites More sharing options...
ucw458 Posted October 29, 2010 Report Share Posted October 29, 2010 did you leave the black canister? the one beside the power steering resivor? or did you remove it too.. The canister is a vac resivour for the HVAC controls. If you remove it you may have HVAC control issues when boosting. Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2010 Author Report Share Posted October 29, 2010 The canister is a vac resivour for the HVAC controls. If you remove it you may have HVAC control issues when boosting. yes i know.. the vents always have a slight flow anyway.. ill leace the canister.. thanks for your help.. Link to comment Share on other sites More sharing options...
*HOndaBAbeGt* Posted October 29, 2010 Report Share Posted October 29, 2010 i have all of that stuff off of mine. the vents do seem to always blow a little bit of air at whatever you have it on, cool or hot. WARE YU AT BO0 I LYK UR HONDAAAAA! Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2010 Author Report Share Posted October 29, 2010 (edited) WARE YU AT BO0 I LYK UR HONDAAAAA! whooooooooooooooooooooooooooooooooooo! THE WH0RE IS BACK! Edited October 29, 2010 by 19cturbo Link to comment Share on other sites More sharing options...
