Gyvven Posted October 7, 2010 Report Share Posted October 7, 2010 The lights were working fine then one day they decided to take their time turning on, and then the next day decided they weren't coming on at all. They pop up and down just fine, but they won't turn on. Is this a contact issue in the switch? Or is there a switch up by the lights that completes a circuit once the lights are up? Link to comment Share on other sites More sharing options...
vbrad511 Posted October 7, 2010 Report Share Posted October 7, 2010 Probably dirty fusable links. Check this.... http://starquest.i-x.net/viewtopic.php?t=1180&sid=57fcf0c4279302b7f12df3aeadfc326d Link to comment Share on other sites More sharing options...
Gyvven Posted October 8, 2010 Author Report Share Posted October 8, 2010 Probably dirty fusable links. Check this.... http://starquest.i-x.net/viewtopic.php?t=1180&sid=57fcf0c4279302b7f12df3aeadfc326d Did they change the fusible link box for the 89? I don't seem to have the sub-fusible link box and the one I do have has a plug that says "Tail" in the second position looking front to back. Link to comment Share on other sites More sharing options...
87Black_Stallion Posted October 9, 2010 Report Share Posted October 9, 2010 Did they change the fusible link box for the 89? I don't seem to have the sub-fusible link box and the one I do have has a plug that says "Tail" in the second position looking front to back.Yes 87 relay box's aren't the same as 88-89's. Matter a fact if you stick a 88-89 relay box into a 87 you will have the same problem your having. Link to comment Share on other sites More sharing options...
KY TSI Posted October 19, 2010 Report Share Posted October 19, 2010 The same thing happened to me, first check all your fuseable links, passing light relay, then your switches, my problem was my high beam switch in the steering column, mine gad build up in it, its a stretch but try clicking it fast about thirty or so times, it worked for me. but eventually replace it if this fixes the problem. Link to comment Share on other sites More sharing options...
M Code Posted October 19, 2010 Report Share Posted October 19, 2010 The same thing happened to me, first check all your fuseable links, passing light relay, then your switches, my problem was my high beam switch in the steering column, mine gad build up in it, its a stretch but try clicking it fast about thirty or so times, it worked for me. but eventually replace it if this fixes the problem. Before clicking the switch multiple times, spray some contact kleener in.. NOT WD40..The switch will help to burnish some of its internal contacts.. Just my $0.02... Link to comment Share on other sites More sharing options...
