starquestG54B Posted September 11, 2010 Report Share Posted September 11, 2010 ok here it is. today i replaced the slave cylinder bc my clutch pedal will not openup the clutch fork so i can shift gears. the car has been sitting for over 5 years in someones yard. sofar i have replaced the water pump,plugs,freeze plug and gone thru about 10 gallons of antifreeze and distilled water weeding out all the cooling system leaks. that part is done and now i am only 2 steps away from driving this car on the road. so like i said the clutch pedal has no pressure ATALL and im getting irritated . i spent 3 hours bleeding the slave and getting nothing but the same! if you even touch the pedal it will slam to the floor and need pulled backup. does ANYONE have ANY suggestions? any help would be apprectiated the car is a 89 tsi 5speed with 124,000 miles Link to comment Share on other sites More sharing options...
J_Copeland Posted September 11, 2010 Report Share Posted September 11, 2010 Sounds like the master cylinder is bad. Link to comment Share on other sites More sharing options...
bha280 Posted September 11, 2010 Report Share Posted September 11, 2010 Sounds like the master cylinder is bad.I concur Link to comment Share on other sites More sharing options...
starquestG54B Posted September 11, 2010 Author Report Share Posted September 11, 2010 thanks guys but where is the master? and whats it look like? Link to comment Share on other sites More sharing options...
garychoffmann Posted September 11, 2010 Report Share Posted September 11, 2010 where you add your fluid, that is connected to the master, It's not very hard to get out and is fairly easy. If you look at the fluid reservoir it dumps into the master cylinder. Link to comment Share on other sites More sharing options...
starquestG54B Posted September 11, 2010 Author Report Share Posted September 11, 2010 that thing under the brake res? Link to comment Share on other sites More sharing options...
Guest Posted September 11, 2010 Report Share Posted September 11, 2010 Clutch master, the one with the small reservoir tank, just under the brake master. Replace it, bleed it, you're good to go. Link to comment Share on other sites More sharing options...
Indiana Posted September 11, 2010 Report Share Posted September 11, 2010 The master has ran too low on fluid and you must bleed it again you were just wasting your time with the slave. Take the hard line off of the master, have someone push the pedal down, you cover the hole for the line with your finger then have them pull the pedal back up. As the pedal is pulled up and you have the hole covered up the cylinder is now forced to suck in the fluid from the reservoir rather than the much easier to suck back up air that's in the line. Do this a few times and watch and tell them to push the pedal slowly because it will blast fluid out. Poke the line back in and tighten it back down then just don't let the reservoir run out and then gravity bleed the slave again, until you have to refill the reservoir at least twice or three times just do not let it run out then put in the bleeder and it should work. That make sense? Same thing you do if you got a new brake master cylinder you will pump it all day and it won't ever get fluid into the two chambers inside the cylinder if it just sucks the air in instead. Link to comment Share on other sites More sharing options...
Shelby Posted September 11, 2010 Report Share Posted September 11, 2010 (edited) man what a load'd question,, may we ask where you put in the new fluid while you were bleeding the clutch slave http://www.starquestclub.com/forum/public/style_emoticons/default/smile.gif age not useage is the hardest on hyd parts,, seting for years and not moveing will alow corrosion to build up in the piston bore,, now after many years you depess the clutch petal the rubber seals on the master piston gets rip'd to bits by the rought build up , makeing the clutch master useless and in need of a rebuild or replacement Edited September 11, 2010 by Shelby Link to comment Share on other sites More sharing options...
starquestG54B Posted September 11, 2010 Author Report Share Posted September 11, 2010 today i removed the master opened it up ,cleaned ALL the black sludge out , compressed the piston in & it held pressure so then i reinstaled , bled it all out and it worked good! thanks guys Link to comment Share on other sites More sharing options...
