TurboDoorHandles Posted September 8, 2010 Report Share Posted September 8, 2010 Anyone know what the heck this is? It seems like some kind of fcd or something, btu I have no idea. Plugs seem factory, but it definately isnt anything I've ever seen on a sq http://nwstarquest.com/83mysteryharness.jpg Link to comment Share on other sites More sharing options...
shoquest2007 Posted September 8, 2010 Report Share Posted September 8, 2010 I may be wrong, but I beleive that was a harness that delt with the injectors on the 83 models. The harness was peice you show was added as a fix. I again am not a hundred percent sure. Link to comment Share on other sites More sharing options...
TurboDoorHandles Posted September 9, 2010 Author Report Share Posted September 9, 2010 I really won't have an idea what it does until I get a ecu pinout. I can't find any Mitsubishi markings anywhere or even a pn the wires are also not color coded Link to comment Share on other sites More sharing options...
Komeuppance Posted September 9, 2010 Report Share Posted September 9, 2010 I may be wrong, but I beleive that was a harness that delt with the injectors on the 83 models. The harness was peice you show was added as a fix. I again am not a hundred percent sure. I'm pretty sure that's what it is. The 83's were burning up injectors because they were being "overdriven". Factory issued a patch harness to solve the problem. -Robert Link to comment Share on other sites More sharing options...
Indiana Posted September 12, 2010 Report Share Posted September 12, 2010 They did a TSB mod that put a modulator under the dash near the ECU that limited the TPS voltage to only 3volts. It had something to do with driveability. I can get you the TSB if you like. Link to comment Share on other sites More sharing options...
TurboDoorHandles Posted September 19, 2010 Author Report Share Posted September 19, 2010 They did a TSB mod that put a modulator under the dash near the ECU that limited the TPS voltage to only 3volts. It had something to do with driveability. I can get you the TSB if you like. I'd love to get the tsb if you dont mind. Link to comment Share on other sites More sharing options...
