19cturbo Posted February 14, 2010 Report Share Posted February 14, 2010 im taking out my charcoal canister and i was wondering what yall done with the line comming from the gas tank.. do you just leave it or route it out the back? thanks mike. Link to comment Share on other sites More sharing options...
patra_is_here Posted February 14, 2010 Report Share Posted February 14, 2010 you can just leave it vented to the air. why are you pulling the charcoal canister. that thing filters gas vapors, and i personally wouldn't want extra gas vapors in my engine bay and eventually going into the air vents. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted February 14, 2010 Report Share Posted February 14, 2010 I let mine vent back by the tank, with a filter on the end. Never noticed any gas fumage. Link to comment Share on other sites More sharing options...
patra_is_here Posted February 14, 2010 Report Share Posted February 14, 2010 yeah if you vent by the tank then you probably wouldnt smell much. Link to comment Share on other sites More sharing options...
19cturbo Posted February 14, 2010 Author Report Share Posted February 14, 2010 thats what i was asking, when i go mpi i plan on running my intercooler pipe through the hole.. Link to comment Share on other sites More sharing options...
Killtodie Posted February 15, 2010 Report Share Posted February 15, 2010 what is the point of this canister? and isnt it supposed to be changed out? charcoal filters something, is it supposed to ever be changed out? Link to comment Share on other sites More sharing options...
Maxzillian Posted February 15, 2010 Report Share Posted February 15, 2010 The charcoal canister serves as the "filter" for the gas tank. When gas vapors are formed and pressure builds in the tank, this pressure is allowed to release through the charcoal canister. However, the canister will trap and store the gas fumes until the next time the engine is ran. At that point a valve opens allowing the charcoal canister to be vented to the air intake of the engine. The engine consumes the gas fumes in an effort to eliminate the pollution caused by the gas vapors being released to the atmosphere. Link to comment Share on other sites More sharing options...
pitboss Posted February 15, 2010 Report Share Posted February 15, 2010 I just put a vacuum line on the hard line and ran it down into a hole in the frame rail by the engine mount. Link to comment Share on other sites More sharing options...
Technology Posted February 15, 2010 Report Share Posted February 15, 2010 Something you all should know. I recently took out this line from the engine bay to reduce clutter. and up by the wiper motor there is a check valve and it only works when vacuum from the engine is applied to the charcoal canister. I didn't understand why it wouldn't just let the pressure of the vapors flow as they wish, but it's probably an emissions thing. Anyway, if you don't remove the check valve back there, the pressure has no way to escape. You may notice that you hear a whooshing sound when you open your filler cap if you have eliminated the charcoal canister, but not the check valve. That's why there are the two vac lines running over there. One is for the vapors. IIRC, the other is for the 7/10psi wastegate solenoid on 88-89 cars. Link to comment Share on other sites More sharing options...
Killtodie Posted February 15, 2010 Report Share Posted February 15, 2010 I had mine removed, what check valve are you describing Tech? Mind providing a pic and/or a solution? Link to comment Share on other sites More sharing options...
Technology Posted February 15, 2010 Report Share Posted February 15, 2010 I might be able to get a pic later, but for right now, it's an L shaped white plastic thing bolted to the firewall near where the ABS canister used to be, kind of under the wiper motor. Just follow that fuel vapor line back to it. The solution is to remove that and maybe add vac hose so it doesn't vent right by the exhaust pipe. Link to comment Share on other sites More sharing options...
Killtodie Posted February 15, 2010 Report Share Posted February 15, 2010 I have a mess of wires and other lines there, a pic of it would be very helpful. Thanks Link to comment Share on other sites More sharing options...
Big Al Posted February 15, 2010 Report Share Posted February 15, 2010 Guess my check valve is broke? I've never noticed any fuel smell from my car and I've had that thing gone for 2 years at least now. I just left the hard line sit right where it was. One of these days I'll get around to cleaning that out but not today that's for sure. I've also never had any whoosh when I took the gas cap off. Meh no harm no foul right? I've got other issues that take precedence over that anyways to deal with first. Link to comment Share on other sites More sharing options...
strang3majik Posted February 15, 2010 Report Share Posted February 15, 2010 mine does the whoosh sound when I open the cap with the charcoal canister in place. Should it? Link to comment Share on other sites More sharing options...
