starion/conquest changes 1983-1989
joey_crandall
History and development
of the
Mitsubishi Starion and Chrysler Conquest
1982 to 1989
In the beginning:
Mitsubishi Heavy Industries, the parent company to Mitsubishi Motors is one of the worlds largest corporations, dating back prior to 1937. Mitsubishi Motors Division is ranked among the 10 largest automobile manufacturers in the world. As a side note, Mitsubishi is also the only automotive manufacturer in the world that builds their own turbochargers!
In 1972, Chrysler Corporation purchased a minor percentage of Mitsubishi Motors stock that gained them a seat on the board of directors. This opened up Chryslers ability to introduce a variety of low cost, fuel efficient cars toting the Chrysler, Plymouth or Dodge banner. We saw many cars, such as the Champ, Colt, Arrow, Challenger, Sapporo, mini trucks roll off Chrysler's lots and home in the hands of happy consumers. Many of Chryslers US built cars shared Mitsubishi power plants
(i.e. LeBaron, Dodge 400, Reliant, and Aries.)
It was to no-ones surprise when they announced their intended entry to the US automotive market in 1983. Having gained knowledge of what the US consumers wanted through their partnership with Chrysler Corporation, the car manufacture stood ready to strike out on their own.
To introduce themselves in October of 1982, a modest line-up of models prove sufficient. These were the Cordia, Tredia, Montero, 2WD and 4WD trucks, and of course, their Flagship, the Starion.
The Starion was to be designed and built to go head to head with other Japanese sports coupes that were now enjoying an exclusive niche in the US market. These were the Datsun 280ZX, powered by an in-line-6, and the Toyota Celica Supra, also with an in-line 6. Needless to say, Mitsubishi's quick little 4 cylinder turbo sent Datsun and Toyota scrambling back to the design departments for turbos of their very own!
Chrysler also released the Starion under their own banner in 1984, displaying the name "Conquest", and they played a major role in refining the cars capabilities and appearance. With joint cooperation between the two industry leaders, we saw the Star/Quest grow and mature through its 7½ ~year production life. while other manufacturers were redesigning their whole car, in an attempt to stay ahead. The Star/Quest, however, simply got better, proving an already excellent design.
General Information:
POWER Plant:
Mitsubishi Built 2.6 liter(2555cm³/155.9 cid) inline 4
Model G54B
Mitsubishi built TD05 Turbocharger
Single Overhead Cam, Chain drive
Hemispherical combustion chambers
Patented MCA Jet valve (for Combustion chamber "Swirl")
Patented Twin Silent Shafts for engine balance *
Throttle Body Injection (EFI)
Bore/Stroke 3.59"/3.86"
Compression Ratio 7.0:1
Clearance Volume 6.39cc
145hp @ 5000rpm
185 lb-ft torque @ 2500rpm
Clutch Diameter: 8"
5th gear (overdrive)ratio 0.86:1
Final drive ratio 3.54:1
Starter; 900w direct drive
Chassis:
Uni-Body construction
Front engine, rear drive
Length 173.2"
Weight 68.3"
Height 50.2"
Wheel base 95.9"
Curb Weight 3037lbs (5spd) 3097lbs (auto)
Drag Coefficient = 0.35
Suspension:
Front:
Independent, McPherson Strut Design
With Stabilizer Bar
Rear: (Chapman design)
Independent, McPherson Struts
With Stabilizer Bars (front & Rear)
Brakes:
Power Assisted
8" Ventilated Disks front and rear
*Later licensed to Porsche for use on 944
Subtile Differences Between the Conquest and Starion
Starion's grill was painted black while Conquest's is Body Color
Starion Taillights had wide grooves while Conquest's were tight
Starion wasn't available with a lighted vanity mirror
1983 1984 1985 1986 1987 1988 1989
1983:
Starion EX, 2+2 Coupe (base Model)
Starion LS, 2+2 Coupe (Luxury Sport)
First production year of the Starion was actually mid 1982.
LS included Air-conditioning, 6 way adjustable seats, digital display, and 8 speaker sound system standard.
7.0:1 compression
Flat sided body only.
Identified by fake hood scoops, and :TURBO decal behind doors.
Introduced unique door mounted seat belts
5spd manual transmission only
Transmision production change ('82.5-03/83)(04/83-04/85)
Block change (82.5-01/83)(02/83-08/85)
Oil pump change (82.5-01/83)(02/83-end)
Oil cooler added (06/83-05/87)
14"x 6" 4 Bolt rims
Available colors:
Exterior
Sand Metallic
Interior
Red
Available Options:
Air Conditioning (EX)
Sunroof (EX/LS)
Leather Seat Package (LS)
Limited Slip Differential
Technica Package included:
Limited slip Differential
Anti lock rear brakes
Digital Insturmentation
1984:
Starion LS
Starion LE
Starion ES
First production year of the Conquest. Sold under Dodge, and Chrysler/Plymoth banner
(Note: The "Conquest" was never sold in Japan)
Drivetrain Changes:
P195/70R-14 on 14"x6" alloy rims standard
First year Automatic was offered
(Used 1200w, reduction drive starter)
Conquest receives quicker stearing gear
(14.3:1 instead of Starions 16.0:1)
Manual transmition change, ?? models (12/84-09/85)
Chassis Changes:
Hood Scoops removed
"Turbo" logo shrunk and moved to door handles Conquest had "Voice Box"
Grill changes to body color
Front Chin spoiler moved forward, and angled back
"B-pillar" vent changed to single slot (Conquest)
Front bumper looses license-plate aperture
Pin striping removed (Conquest)
New ABS computer designed
Available colors:
Starion:
Black Exterior w/ Red Interior
Red Exterior w/ Gray Interior
Conquest:
Maroon Exterior w/ Maroon interior
Available Options:
Automatic Transmission (Starion LE, Conquest)
Air conditioning (Starion LS, Conquest)
Sunroof
Tire Package
P215/60R-15s on 15" x 6.5" alloy rims
Lower gold body treatment
TSB 21-18-90
1985:
Starion LS
Starion LE
Starion ES
Starion ESI (1985½)
Conquest LE
Drivetrain Changes:
Water cooled turbine bearing housing (All)
Stronger Driveline (5 lug tire hubs on ESI )
Manual transmition change ??model (10/85-05/87)
Manual transmition change ??model (06/85-05/87)
Block change (09/85-end)
Chassis Changes:
Available Colors:
Pearl Exterior w/ Blue?? Interior
Gold Exterior w/ ?????? Interior
White Exterior w/ Tan Interior (Conquest)
Burgundy Exterior w/ Burgundy Interior
Red and Black?? w/ Gray Interior
Available Options:
Auto Transmission (Starion LE, Conquest)
Air Conditioning (Starion LS, Conquest)
Technica Package (Conquest)
Digital Instrument Cluster
Electronic Voice Alert
Body Side Trim
ESI Package (actually a 1985.5 model)
170hp @ 5000rpm (SAE Net)
220ft/lbs @ 2500
7.5 PSI boost
Intercooler
Compression 7.0:1
Rear Wheel ABS (EIS only)
15"x6.5" 5-bolt Rims
P215/60HR-15 tires
Available w/Manual Transmission only
9.92" rotors (front), 9.65" (rear)
Steering Ratio: 14.3:1
Stabilizer Bars = .83"(front), .71"(Rear)
Technical Service Bulletins Issued:
TSB 18-52-86
TSB 21-10-90
TSB 21-18-90
1986:
Starion LE
Starion ESI-R
Conquest LE
Conquest TSI
Introduction of the Starion ESI-R
(Euro Sport Intercooled-Rally)
Introduction of the Conquest TSI
(Turbo Sport Intercooled)
Drivetrain Changes:
Automatic Valve lash adjusters installed
Brake rotors increase to 10.8" (front) and 10.4" (rear)
215/60R-15, 15 x 6.5" 4 bolt alloy rims standard
New computer, with High altitude compensation
Chassis Changes:
First Wide Body (Flared Fender) design (ESI-R & TSI)
B-Pillar Vent changed to one vertical slot, (Starion)
Rear Spoiler, made standard
New Cyclops Brake Light
Improved ETACS Computer w/wiper speed control, doorlock
control, and 30 delay for power windows
New Interior trim
Bodyside moldings made standard
Rear washer/wiper made standard
Steering ratio increased from 3.0 to 2.8 turns lock to lock
Control arm pivot point raised (ESI-R/TSI)
Control arms are 1" longer (ESI-R/TSI)
Stearing Knuckle angles adjusted (ESI-R/TSI)
Stouter Idler arm (ESI-R/TSI)
Stronger Struts (ESI-R/TSI)
Wheel Offset Changed (ESI-R/TSI)
Available colors:
Black Exterior w/ Black Interior (Conquest)
Silver Exterior w/ Black Interior (Starion)
Red Exterior w/ Burgandy Interior (Conquest)
White Exterior w/ Burgundy Interior (Starion)
Available Options:
Air Conditioning (Conquest)
Leather/Digital Package (Starion LE)
Illuminated Vanity Mirrors
ESI-R Package
176hp @ 5000rpm (SAE Net)
223ft/lb @2500rpm
Compression 7.1:1
Flaired Fenders
16"x 7" (F) 16"x 8"® 5 bolt alloy rims
TSB 18-52-86
TSB 21-08-90
TSB 21-10-90
TSB 21-18-90
1987:
Base Model = 146hp @ 5000rpm, 185 lb-ft torque @ 2500rpm
Starion LE
Starion ESI-R
Conquest LE
Final year of the ES Model?
Drivetrain Changes:
15"x 6.5" Wheels P215/60HR15
Improved fuel management system
Fuel cut circuit removed
Manual transmition change (06/87-end)
Piston and pin change (82.5-05/87)(06/87-end)
Flywheel change (82.5-05/87)(06/87-end)
Oil cooler change (06/87-end)
Chassis Changes:
Rear Axil Ratio 3.54:1
TC05 Turbocharger
Passive Restraint seat belts
Available colors:
Bright Silver Exterior w/ Dark Red Interior (Starion/Conquest/TSi)
Black Exterior w/ Black Interior (Starion/Conquest/TSi)
Bright Red Exterior w/ Black Interior (TSi)
Dark Red Exterior w/ Dark Red Interior (Starion/Conquest>
Driftwood Exterior w/ Dark Red Interior (Conquest/TSi)
Gold Exterior w/ Black Interior (Starion/Conquest/TSi)
Medium Blue Exterior w/ Black Interior (Conquest/TSi)
White Exterior w/ Dark Red Interior (Conquest/TSi)
Available Options:
Leather seat trim
Sunroof
Floor Mats
AM Stereo/FM Stereo (Standard on TSI)
Technica Package (Conquest Only)
AM Stereo/FM Stereo
Leather Wrap Steering Wheel w/radio controls
TSI/ESI-R Package:
176hp @ 5000rpm, 223 lb-ft torque @ 2500rpm
7.5 PSI Boost
Intercooler
Rear Wheel ABS
16" Wheels P205/55VR16 (7"front) P225/50VR16 (8"Rear)
Unique Air Dam
Fender Flares
Lower Bodyside Sill Extensions
Leather wrap Steering Wheel w/radio controls
AM Stereo/FM Stereo
Performance sound exhaust
Remote/heated outside mirrors
TSB 18-52-86
TSB 21-10-90
TSB 21-18-90
1988:
Starion ESI
Starion ESI-R
Conquest TSI
Drivetrain Changes:
Boost increased to 10 PSI
188HP @ 5000rpm 234 lb-ft torque @ 2500rpm
Chassis Changes:
Available Colors:
Electric Blue Exterior w/ Black Interior (TSi)
Canary Yellow Exterior w/ Black Interior (TSi)
White Exterior w/ Dark Red Interior (Conquest)
White Exterior w/ Beige Interior (Starion)
Red Exterior w/ Black Interior (Starion/Conquest)
Black Exterior w/ Black Interior (Conquest/Starion)
Maroon Exterior w/ Maroon Interior (Conquest)
Available Options:
Sport Handling Package (Starion ESI-R, Conquest TSI)
225/50-16 on 8"rims (front)
245/45-16 on 9"rims (rear)
8 position, manually adjustable shocks
Cosmetics aero Wheel covers
Air Conditioning (Starion ESI, Conquest TSI)
Leather seat trim (Starion ESI-R, Conquest TSI)
Automatic Transmission (Starion EIS-R, Conquest TSI)
TSB 21-08-90
TSB 21-10-90
TSB 21-18-90
1989:
Starion ESI-R
Conquest TSI
Final production year for both cars.
Drivetrain Changes:
Chassis Changes:
New Three point harness for rear passengers
New One Touch automatic down for Power windows
New two position power antenna
New standard sport bucket seats
Available Colors:
Red Exterior w/ Black or Buckskin/Black Interior
White Exterior w/ Dark Red or Buckskin/Black
Yellow Exterior w/ Black or Buckskin/Black Interior
Black Exterior w/ Black or Buckskin/Black Interior
Buckskin Exterior w/ Black or Buckskin/Black Interior
Silver Exterior w/ Dark Red or Black Interior
Available Options:
Air Conditioning
Floor Mats
Performance Handling Package
5-Way Adjustable leather sport bucket seats
Sun Roof
TSB 21-08-90
TSB 21-10-90
Technical Service Bulletins Discription:
TSB 18-52-86 Rough Idle, Faulty ECU
TSB 20-08-90 5spd Buzz through Shifter, Replace shifter
TSB 21-10-90 5spd Model KM132 redesigned 5th gear.
TSB 21-18-90 Auto Trans Overdrive switch
Recalls:
1988 Catalytic Converter
1988 Rod Bearings
SOME UNKNOWN DATA:
Rim increase from 14" to 15" ?
Clutch size Increase 8"-9"-10" ?
Bumper to Bumper Warrantee 3yr/36,000 mile
Drive train Warrantee 3yr/50,000 mile
Rust Warrantee 5yr/unlimited mile
Acknowegements:
This data has been collected through data released by a number of publications.
Chrysler Publications Archives
Chrysler Service Department
Mitsubishi Motors Corperation
Turbo and High performance Magazine
Mitsubishi Sports Car Club of America
Road and Track
Car an Driver
Popular Science
Motor Trend
Chiltons
Haynes
NADA Blue Book
NOTE: Production changes with dates, have been identified by part number changes.
This section is not intended to infringe on any publication rights, but to provide information to fellow enthusiasts of the Conquest and Starion
I remember reading this years ago.
You would think who ever wrote it would check for spelling mistakes.
The auto down was for the drivers window only.
I dont recall my 89 having this. Edited by Mech
  • 8 months later...
References? Sorry, not trying to be a wise a** this time, but there is always someone claiming they have personal correspondence withe Mitsubishi dating back to 198x ;).
I had such correspondence, and can prove it. The original post is so full of holes and inaccuracies that if it were a ship, it'd sink before it left the port.
  • 5 years later...
