Funky Phil Posted September 5, 2008 Report Share Posted September 5, 2008 Trying to link up and atleast download the map thats already on but keep getting the error message "failed to connect with controller" ???? Im using a serial to usb convertor. Anyone have similar issues?? phil Link to comment Share on other sites More sharing options...
Funky Phil Posted September 5, 2008 Author Report Share Posted September 5, 2008 oh yeah, dash display does not work but i can connect and watch realtime on the fuel controller. Link to comment Share on other sites More sharing options...
83TechMaster Posted September 6, 2008 Report Share Posted September 6, 2008 Are you using the ignition pro software? Trying to link up and atleast download the map thats already on but keep getting the error message "failed to connect with controller" ???? Im using a serial to usb convertor. Anyone have similar issues?? phil Link to comment Share on other sites More sharing options...
Shelby Posted September 7, 2008 Report Share Posted September 7, 2008 (edited) you may need to try and find the proper drivers for the adaptor, i have heard a lot of the newer lap tops don't like to read the ecu thru the usb port Xp has a problem loading the drivers even tho it says it has them i remember when the Tainters were down here their pc would not connect like 50% of the time and drop out ocasionaly on the usb port just a thought are you turning on the lap top befor or after connecting to the lap top,, it may not be assigning an irq if the lap top usb port is not in use when it boots up Edited September 7, 2008 by Shelby Link to comment Share on other sites More sharing options...
Funky Phil Posted September 9, 2008 Author Report Share Posted September 9, 2008 Yes, Im using the fip software. But the problem is only with the ignition computer. I can connect to the FC all day and monitor but anytime I try connecting with the IC it give me the error message. phil Link to comment Share on other sites More sharing options...
Shelby Posted September 11, 2008 Report Share Posted September 11, 2008 i have one but never install'd it but i seem to recall it requires a diff soft ware program then the fuel program Link to comment Share on other sites More sharing options...
Funky Phil Posted September 11, 2008 Author Report Share Posted September 11, 2008 Yeah, I have both the programs but the ignition pro doesnt respond...? Link to comment Share on other sites More sharing options...
Shelby Posted September 11, 2008 Report Share Posted September 11, 2008 wish i could be of more help but i have never try'd connecting to mine Link to comment Share on other sites More sharing options...
Funky Phil Posted September 11, 2008 Author Report Share Posted September 11, 2008 thats cool I wish FIP would hop on here but probably wont happen. Thanks anyway Shelby. phil Link to comment Share on other sites More sharing options...
Shelby Posted September 12, 2008 Report Share Posted September 12, 2008 you might check the connection baud rate etc and you might check on the older programs that may work but i remember when theTainters try'd to connect to a couple ms ecus with their lap top (usb) it wouldn't work so they use'd my lap top while they were down here Link to comment Share on other sites More sharing options...
jahjah Posted September 12, 2008 Report Share Posted September 12, 2008 Wow... mine connects okay... Link to comment Share on other sites More sharing options...
BaltTSI Posted September 13, 2008 Report Share Posted September 13, 2008 (edited) I had the same problem with my Pro2 setup , somewhere I found some info on the USB to Serial adapter, the recommendation was to go buy the one Radio Shack makes, or sells, and it does come with a driver, has worked perfect ever since, as long as I turn the Megatune program off before I shut the car off, that locks up my laptop Edited September 13, 2008 by BaltTSI Link to comment Share on other sites More sharing options...
Funky Phil Posted September 13, 2008 Author Report Share Posted September 13, 2008 yeah, i got mine from radio shack with the install disc. Have you messed with the ignition program?? Everyone keeps saying megatune. I can mess with megatune all day just not ign pro. Link to comment Share on other sites More sharing options...
BaltTSI Posted September 13, 2008 Report Share Posted September 13, 2008 No, I don't have the ignition setup Link to comment Share on other sites More sharing options...
Shelby Posted September 14, 2008 Report Share Posted September 14, 2008 it comes with a pre set program the first thing you do after connecting to the ecu is save the curent program for later back up , and any changes made has to be save'd to ecu along with a new save'd back up of the change'd program Link to comment Share on other sites More sharing options...
