AustinTSI Posted April 17, 2013 Report Share Posted April 17, 2013 (edited) I'm trying to find out if my front camber plates will be useable when I swap the standard Starion front end with a S13 front end. So I need to know what the diameter of the strut rod is for each each of them. I specifically need the diameter of the part that would be inside of the rubber insulator or inside of the camber plate. Edited April 17, 2013 by AustinTSI Link to comment Share on other sites More sharing options...
AustinTSI Posted April 18, 2013 Author Report Share Posted April 18, 2013 I don't know if the shock absorber rod has a taper to it that actually contacts the camber plate or how much of a step down there may be from the outside diameter of the rod itself but I found that the S14 has a rod diameter in the rear of 12.5mm and the front is 20mm if I remember correctly. Link to comment Share on other sites More sharing options...
Komeuppance Posted April 18, 2013 Report Share Posted April 18, 2013 Depending on what plates you have, you can just change out the nut. This is what's required when using MR2 struts since they're slightly larger. -Robert Link to comment Share on other sites More sharing options...
patra_is_here Posted April 30, 2013 Report Share Posted April 30, 2013 (edited) or you just get a small spacer to make up the difference in size: http://www.profileracing.com/estore/images/product-thumbnail-images/63/tubespacers_5193_236.jpg Edited April 30, 2013 by patra_is_here Link to comment Share on other sites More sharing options...
BOOSTED88tsi Posted April 30, 2013 Report Share Posted April 30, 2013 ^most camber plates come with those Link to comment Share on other sites More sharing options...
BOOSTED88tsi Posted April 30, 2013 Report Share Posted April 30, 2013 i could have answered this for you haha. Im running the s14 struts into MK1 starion camber plates. i had the s14 struts in the stock top hats for about a month while i got camber plates and would not recommend it changing to the camber plates made my steering feel 100% better as it got rid of all the slop in the top hat. Link to comment Share on other sites More sharing options...
AustinTSI Posted May 1, 2013 Author Report Share Posted May 1, 2013 I've got the Stedebani camber plates front and back and would like to keep them but I wasn't sure if the s14 shock absorber rod would be too big or too small; or fit just right! Link to comment Share on other sites More sharing options...
