TexasQuest Posted April 1, 2013 Report Share Posted April 1, 2013 Got some slightly used ST swaybars I wanna install this spring but I need to get some new swaybar bushings for them, the D shaped ones. Anybody know which ones fit the factory brackets the best or does it matter? Energy Suspension? Prothane? Link to comment Share on other sites More sharing options...
kidjc Posted April 2, 2013 Report Share Posted April 2, 2013 ST has a kit for the bars, I believe the "hardware kit # is 51180-777, (won't come w/ rear though) as know this, the rear sway (unless you want to reconfigure it all) you have to use the old stock bushings, kinda "squeeze" them in there. The "D" style you're talk'n about? Enery Suspension Red Polyurethane # 9.5107R / 13/16 Stab/Bush (they're BIG). Hope this helps Link to comment Share on other sites More sharing options...
TexasQuest Posted April 2, 2013 Author Report Share Posted April 2, 2013 I was afraid that urethane bushings won't fit the rear brackets, that's why ST doesn't supply them. I've got endlinks for them and used front bar urethane bracket bushings and rear rubber bushings but they're worn a little. I probably use what I've got, thanks for the help man. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted April 2, 2013 Report Share Posted April 2, 2013 You can get some that have the same inner diameter and trim the outside Link to comment Share on other sites More sharing options...
TexasQuest Posted April 2, 2013 Author Report Share Posted April 2, 2013 Yeah I was thinking about doing that with a dremel or something..... Link to comment Share on other sites More sharing options...
