Matthewr1 Posted August 25, 2012 Report Share Posted August 25, 2012 I have a stock 88 starion ESiR with a auto Trans. The car runs great but won't shift I can do it manually but it won't shift on its own. Now I know they have a vacuum seloniod. But does it have a computer that shifts the Trans that I might have to replace? Quote Link to comment Share on other sites More sharing options...
The Rabbit1 Posted August 25, 2012 Report Share Posted August 25, 2012 no computer, the vacuum solenoid and the governor are what shift it. Quote Link to comment Share on other sites More sharing options...
Matthewr1 Posted August 25, 2012 Author Report Share Posted August 25, 2012 Well that's great to here because I found a small crack in the vacuum line off the intake and replaced it but haven't driven it yet I hope that's all it was! Fingers crossed. Thanks Quote Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 25, 2012 Report Share Posted August 25, 2012 The vac line and modulator won't/can't keep the trans from doing anything. They just modify the shifting slightly. First step should be to reset or verify the shifter linkage. Quote Link to comment Share on other sites More sharing options...
Indiana Posted August 26, 2012 Report Share Posted August 26, 2012 Clogged up valvebody. Shifter has nothing to do with it, its either in drive or its not and the modulator changes how much pressure goes to keep the band tight around the drum so it doesn't slip too much. The fluid is all burned up, nobody likely ever chanced it, the cooler (POS) behind the airdam usually mashed so the tranny burns up. All that crap from overheated fluid and burnt up clutch and steels ends up inside the valvebody and it won't shift worth a damn. Rebuild it then it will be better than you could ever imagine and be twice times as strong as a stock manual tranny and you won't have to pay 400.00 for a clutch. Quote Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 26, 2012 Report Share Posted August 26, 2012 The shifter can indicate its in drive and the trans is not in drive. Thats why I say to verify it first. Easy to do and keeps a person from spending time and money screwing up a perfectly functional trans. Quote Link to comment Share on other sites More sharing options...
Matthewr1 Posted August 26, 2012 Author Report Share Posted August 26, 2012 The shifter is in the correct position. And the fluid has been changed regularly until the guy I got it from let it sit. But I'm still going to drop the pan and see how it looks.. Before he let it sit a shop had told the guy it was a $500 peace that was messed up. That's what made me think these had a computer. Quote Link to comment Share on other sites More sharing options...
Matthewr1 Posted August 26, 2012 Author Report Share Posted August 26, 2012 U know I have a extra 88 auto Trans. Where is the best place to get a rebuild kit for it. I will just rebuild the other and put it in Quote Link to comment Share on other sites More sharing options...
The Rabbit1 Posted August 26, 2012 Report Share Posted August 26, 2012 MikeMeyerhoff can get you some parts, but any Dacco or Transtar location can get you rebuild parts and they can even get the performance clutches and bands last time I checked when I was rebuilding mine. Quote Link to comment Share on other sites More sharing options...
Matthewr1 Posted August 26, 2012 Author Report Share Posted August 26, 2012 Someone was telling me rockauto had them for our cara but I can't seem to find them Quote Link to comment Share on other sites More sharing options...
The Rabbit1 Posted August 27, 2012 Report Share Posted August 27, 2012 Someone was telling me rockauto had them for our cara but I can't seem to find themI wouldn't buy trans parts from them, U don't want to be redoing it for being cheap. Quote Link to comment Share on other sites More sharing options...
Matthewr1 Posted August 27, 2012 Author Report Share Posted August 27, 2012 Alright lol I'm guessing not good parts. Ok I will talk to who you said I should Quote Link to comment Share on other sites More sharing options...
The Rabbit1 Posted August 27, 2012 Report Share Posted August 27, 2012 they have some good parts, just not worth trying to save a few bucks when it comes to transmissions. It's really not that expensive to get parts for the 4N71B Quote Link to comment Share on other sites More sharing options...
89PalermoSHP Posted August 30, 2012 Report Share Posted August 30, 2012 You want to look for AltoUSA friction clutches. If a distributor cant find them for you, call Alto directly. Get this modulator(and only this modulator) when your ready for it. http://www.transmissionpartsusa.com/Nissan_L3N71B_L4N71B_Turbo_modulator_1971_on_p/820-000082885.htm Quote Link to comment Share on other sites More sharing options...
Matthewr1 Posted August 30, 2012 Author Report Share Posted August 30, 2012 Thanks I will do that! Why just tht modulator? Quote Link to comment Share on other sites More sharing options...
