how to set up a dual boot,, win Xp and win7 & seperate hard drvs
11 replies to this topic
#1 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 38,988 posts
Posted 08 November 2011 - 01:34 AM
just how hard it this t do
88TSI Silver
89TSI red auto
#2 RobH
RobH
  • 824 posts
  • Interests:cars
Posted 08 November 2011 - 06:29 AM
it is not hard at all shelby
ill have to put on my thinking cap again to remember
but if you would like i can try and walk you threw this
89 fiji 2jzgte/R154
My Build Thread
Paint http://www.starquest...howtopic=131275
engine swap http://www.starquest...howtopic=127175
#3 Goddard
Goddard
  • 985 posts
  • Interests:art, cars, snowboarding...
Posted 08 November 2011 - 08:07 AM
I want to do the exact same thing.  My new computer came loaded with Wins 7.  I picked up a nasty virus weeks ago and have my system back up and running (in a limited fashion though).  I need to completely reload the OS with some backup discs.  I do however have a lot of expensive XP software on my laptop that would be nice to run on this new desktop computer.  Unfortunately since the software is older it's not working with Wins 7 (keeps crashing).  I was thinking to just buy a XP disc from eBay and forget about 7 all together but maybe a dual boot would be the best of both worlds.  I'm not a huge fan of 7 but I think it's just because I haven't dove into it very deep.  Any help or suggestions would be awesome!
#4 Shelby
Shelby
    Rookie
  • 38,988 posts
Posted 08 November 2011 - 09:04 AM
a little advice about  buying an XP disk,, make sure it  includes SP2 or SP3 in it already or the pc will not even boot up
and if you have win7 professional or ultimate  , it has a built in XP mode you have to  down load from microsoft
88TSI Silver
89TSI red auto
#5 Goddard
Goddard
  • 985 posts
Posted 08 November 2011 - 10:18 AM
Thanks Shelby, I'll look into that.  I think it's probably just 7 Home Edition.
#6 Shelby
Shelby
    Rookie
  • 38,988 posts
Posted 09 November 2011 - 02:58 PM
well start walking but keep it slow ;)
88TSI Silver
89TSI red auto
#7 DryBear
DryBear
  • 652 posts
Posted 09 November 2011 - 05:14 PM
If you are having problems running older software on Windows 7, right click on the application, then select "Properties."
In the window that pops-up, select the "Compatibility" tab. Select the box for "Run this program in compatibility mode," and pick Windows XP service pack 3. Try running it again, and if you still have issues, step the mode down to Windows 2000.
If the program access the disk drive a lot to write files, you may need to use the "run as administrator" option as well.
#8 Shelby
Shelby
    Rookie
  • 38,988 posts
Posted 09 November 2011 - 07:50 PM
XP compatiability mode is an add'd down load for win7  it's not include'd
88TSI Silver
89TSI red auto
#9 DryBear
DryBear
  • 652 posts
Posted 10 November 2011 - 01:53 PM
You are thinking about the virtual XP machine that runs within windows 7 - yes that is a seperate download called "Windows XP Mode" - compatibility mode is built right into Windows 7.
#10 strang3majik
strang3majik
    Hi
  • 5,787 posts
  • Interests:Life, the universe, and everything.
Posted 10 November 2011 - 01:58 PM
You have to install XP first, and in the install blue screen, setup two partitions on the hard drive.  Install XP to one of those.
Then, once the XP install is done, install Windows 7 to the other partition.  Its pretty simple really.  I have my desktop computer like that.
When you boot it up, you have to make the selection of Earlier Version of Windows, or Windows 7.
#11 newquest86
newquest86
  • 445 posts
  • Interests:restoring and modifying cars
Posted 14 November 2011 - 07:44 PM
DITTO!!
86 plymouth conquest njv clearwater head  ARP STUDS schneider springs 3 angle valve job  16g  trilogy injectors bse kit mk1 struts mk1 2.5 exhaust fuel cut mod evc 3 boost controller AEM UEGO WIDEBAND mk1 gauge kit 83 fiberglass hood hard pipes bov lightened flywheel cs 130 gm alt. KN filter drilled and slotted brake rotors jolyrgr braided oil lines
#12 Skullzaflare
Skullzaflare
  • 3,213 posts
  • Interests:Computers, hotrods, ratrods
Posted 23 November 2011 - 12:49 AM
close
if you have your XP key, figure out if its OEM or normal, you can download unmodified torrents ISO files, for an updated version
first, as above, you will install XP on the drive you want, i recommend formatting both, so when you bring up Win7 its easier to notice
after installing, reboot, run Win7 disc, tell it you are not upgrading, delete the partition on the 2nd drive, and tell it to install
it will automatically setup the dual boot screen, it will default load windows 7 if you dont interrupt it, but you can change that
