Wakeman17 Posted January 12, 2011 Report Share Posted January 12, 2011 What type of oil is recomended for our cars? Link to comment Share on other sites More sharing options...
BuGG Posted January 12, 2011 Report Share Posted January 12, 2011 (edited) Should run 20-50 but can also run 15-50. The motor is not built for 10w or lower. Edited January 12, 2011 by BuGG Link to comment Share on other sites More sharing options...
rcm Posted January 12, 2011 Report Share Posted January 12, 2011 The factory manual has 20w/50 down to 32 degrees,below that tempature it is 10w/30.Most all ususe 20w/50 though sae. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 Stock or rebuilt performance engine? Stock: 10w30wt. Performance built: 20w50wt. Bill Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 (edited) The factory manual has 20w/50 down to 32 degrees,below that tempature it is 10w/30.Most all ususe 20w/50 though sae. Where? Does the FSM state to use 20w50wt?? I see 20w20wt,20w40wt,10w30wt and 5w30wt.You don't use 20w50wt unless you engine is built to accept it. Mine is. Look at my modifications.No advice is better than bad advice. I don't give bad advice, just sound advice, Bill Edited January 12, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
rcm Posted January 12, 2011 Report Share Posted January 12, 2011 Correction 20w/40 . Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 Should run 20-50 but can also run 15-50. The motor is not built for 10w or lower. Your wrong. Read the FSM. Bill Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 (edited) Correction 20w/40 . I'm not picking on you, but new members read these forums. We need to give them accurate information.For almost all climates: 10w30wt is best. Bill Edited January 12, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
StallionProject86 Posted January 12, 2011 Report Share Posted January 12, 2011 I'm running 10x40. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 I'm running 10x40. Good choice. Seeings how So.Cal. is cooler this year. Bill Link to comment Share on other sites More sharing options...
rcm Posted January 12, 2011 Report Share Posted January 12, 2011 Well from 32 degrees to 120 degrees for 20w/40 is a pretty broad climate for anywhere coming from the fsmIt is really a matter of preferance ,i use 20w/50,you use 10w30,somebody else uses 15w/50 so for the newbiei look at the the fsm for average climate.Not many drive there quest in -10 below. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 (edited) It is really a matter of preferance ,i use 20w/50,you use 10w30 No, I use 20w50wt. If your engine is not a High Performance built motor. You should use 10w30 or 10w40wt. Ask around about correct oil weights. And look below Edited January 12, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
Wakeman17 Posted January 12, 2011 Author Report Share Posted January 12, 2011 So what should i use for central florida climate? Link to comment Share on other sites More sharing options...
Caliber308 Posted January 12, 2011 Report Share Posted January 12, 2011 10w30wt Link to comment Share on other sites More sharing options...
Starfighterpilot Posted January 13, 2011 Report Share Posted January 13, 2011 This question is like asking ten men which woman is the most beautiful of ten beautiful women. You'll get 10 different answers. This exact same question comes up every month or so. There must be at least 500 posts, not to mention 1000's of replies on this subject in the BS & VM Archives. Do a search for it and you will get more opinions than there are grains of sand on a beach. As was suggested to you in some of your other posts READ THE FSM for MITSU's suggested weights of oil to use for the climate that you live in. For What It's Worth. KEN Link to comment Share on other sites More sharing options...
