reed80 Posted March 11, 2008 Report Share Posted March 11, 2008 well about a few weeks ago i posted about gettin a full g54b engine arp bolt kit. i have finaly got all of the sizes i hope. it took me about 3 days to do. arp sent me a email saying if i got the sizes then they can put together a kit. but even if u just wanna go get a few bolts and need the sizes here they are. now this is for the 88 g54b turbo w/manual trans if any one notices any thing off please let me know so i can fix it the only ones i cant seam to find are the flywheel bolts and the bolts for that holds the cam shaft down. so if u have those sizes and would like to throw them in id aprciate it and here they all are thread pitch is 1.25 if iam not mistakin engine bolts sending unit nut,flange 10mm=1 stud 10x25mm=1 balance shaft cover bolt,flange 6x12mm=2 engine mount bolt and washer,10x20mm=4 rear crankshaft case bolt,flange 6x20mm=5 arp main studs part # 207-5402 cylinder head head stud arp part # 207-4202 acelarator clamp bolt for valve cover bolt.flange 8x12mm=1 valve cover bolt 8x40mm=2 pvc clip stud and nut stud 8x18mm 1 nut 8mm=1 breather pipe bolt bolt.flange 6x12mm=1 bolt flange 8x12mm=1 exhaust manifold stud stud 8x28mm=8 nuts 8mm=8 2 small bolts in back of head 8x25mm=2 2 bolts in front of head 8x50mm=2 intake studs studs.8x28mm=10 nut 8mm=10 hanger, engine front bolt bolt,flange 8x14mm=1 bottom end bolt kit rod studs arp part # 107-6003 camshaft gear bolt bolt and wahser 14x70mm=1 wahser,plain 14mm=1 camshaft sproket holder bolt bolt.flange 6x10mm=4 timing cover bolts bolt,flange 8x68mm=8 bolt,flange 8xx58mm=2 timing cover access cover bolt bolt.flange 6x18mm=2 bolt for front near crank shaft seal bolt.flange,8x73mm=1 rear engine adapter plate bolt and washer 6x12mm=4 oil pickup screen nut nut 8mm=2 oil pan bolts bolt and washer 6x12mm=24 manifold ground cable bolt bolt and washer 8x12mm=1 bolt and wahser 8x28mm=1 oil pump body bolt bolt,flange 6x16mm=1 cover bolts bolt flange 6x38mm=1 6x45mm=1 6x22mm=1 10x15mm=1 flywheel is 12x1.25, arp # 203-2801 heres the bad stainless 300 exhaust manifold studs.. ARP # 400-8013 the harmonic balancer bolt is # 207-2501 Link to comment Share on other sites More sharing options...
randomguy Posted March 11, 2008 Report Share Posted March 11, 2008 well about a few weeks ago i posted about gettin a full g54b engine arp bolt kit. i have finaly got all of the sizes i hope. it took me about 3 days to do. arp sent me a email saying if i got the sizes then they can put together a kit. but even if u just wanna go get a few bolts and need the sizes here they are. now this is for the 88 g54b turbo w/manual trans if any one notices any thing off please let me know so i can fix it the only ones i cant seam to find are the flywheel bolts and the bolts for that holds the cam shaft down. so if u have those sizes and would like to throw them in id aprciate it and here they all are thread pitch is 1.25 if iam not mistakin engine bolts sending unit nut,flange 10mm=1 stud 10x25mm=1 balance shaft cover bolt,flange 6x12mm=2 engine mount bolt and washer,10x20mm=4 rear crankshaft case bolt,flange 6x20mm=5 arp main studs part # 207-5402 cylinder head head stud arp part # 207-4202 acelarator clamp bolt for valve cover bolt.flange 8x12mm=1 valve cover bolt 8x40mm=2 pvc clip stud and nut stud 8x18mm 1 nut 8mm=1 breather pipe bolt bolt.flange 6x12mm=1 bolt flange 8x12mm=1 exhaust manifold stud stud 8x28mm=8 nuts 8mm=8 2 small bolts in back of head 8x25mm=2 2 bolts in front of head 8x50mm=2 intake studs studs.8x28mm=10 nut 8mm=10 hanger, engine front bolt bolt,flange 8x14mm=1 bottom end bolt kit rod studs arp part # 107-6003 camshaft gear bolt bolt and wahser 14x70mm=1 wahser,plain 14mm=1 camshaft sproket holder bolt bolt.flange 6x10mm=4 timing cover bolts bolt,flange 8x68mm=8 bolt,flange 8xx58mm=2 timing cover access cover bolt bolt.flange 6x18mm=2 bolt for front near crank shaft seal bolt.flange,8x73mm=1 rear engine adapter plate bolt and washer 6x12mm=4 oil pickup screen nut nut 8mm=2 oil pan bolts bolt and washer 6x12mm=24 manifold ground cable bolt bolt and washer 8x12mm=1 bolt and wahser 8x28mm=1 oil pump body bolt bolt,flange 6x16mm=1 cover bolts bolt flange 6x38mm=1 6x45mm=1 6x22mm=1 10x15mm=1 flywheel is 12x1.25, arp # 203-2801 heres the bad stainless 300 exhaust manifold studs.. ARP # 400-8013 the harmonic balancer bolt is # 207-2501 http://www.youtube.com/watch?v=Wddgfbc6UMw Link to comment Share on other sites More sharing options...
Casey_L Posted March 11, 2008 Report Share Posted March 11, 2008 I may be interested in something like that. How much would this cost? Link to comment Share on other sites More sharing options...
Komeuppance Posted March 11, 2008 Report Share Posted March 11, 2008 http://www.youtube.com/watch?v=Wddgfbc6UMw LOL...uh... so does that mean you're interested?? BTW, that movie was a disgrace and HUGE disappointment. -Robert Link to comment Share on other sites More sharing options...
reed80 Posted March 11, 2008 Author Report Share Posted March 11, 2008 arp keeps shooting me to difrent plants. i finaly got ahold of a guy today, i just sent him the mesurements. he said if they dont have them on the shelf they will have to be custom made, inwich would be alot more. i should know something by tomorow. i hope anyway Link to comment Share on other sites More sharing options...
88conquestt Posted May 20, 2013 Report Share Posted May 20, 2013 Id order a set for sure! if its really soon. Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted May 20, 2013 Report Share Posted May 20, 2013 http://cdn.head-fi.org/7/73/7329b4cf_threadNecromancy.jpg Link to comment Share on other sites More sharing options...
importwarrior Posted July 6, 2014 Report Share Posted July 6, 2014 this helped a lot thanks. Link to comment Share on other sites More sharing options...
randy Posted July 12, 2014 Report Share Posted July 12, 2014 Great info if ya need new hardware. Link to comment Share on other sites More sharing options...
