flatty86 Posted December 31, 2012 Report Share Posted December 31, 2012 I know I been posting a lot here lately but i'm doing so much to this car.. I looked all over this forum to see if anyone converted their flatty to intercolled.... What is the process and do I have to change out my turbo to accomplish this or modify the plumbing? If anyone can send me a link to a write up that would be great!!! You guys have been a LOT of help with this car. Link to comment Share on other sites More sharing options...
NotStock88 Posted December 31, 2012 Report Share Posted December 31, 2012 check the faq archives, I found it there - http://www.starquestclub.com/forum/index.php?showtopic=27981 Link to comment Share on other sites More sharing options...
flatty86 Posted January 1, 2013 Author Report Share Posted January 1, 2013 THANKS BUDDY Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 1, 2013 Report Share Posted January 1, 2013 OLIVE8 , ask him Link to comment Share on other sites More sharing options...
flatty86 Posted January 2, 2013 Author Report Share Posted January 2, 2013 Does anybody know if I can use the same oil cooler lines that I currently have, once I add the TSI turbo? Or do i have to change the lines as well? Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 2, 2013 Report Share Posted January 2, 2013 (edited) Does anybody know if I can use the same oil cooler lines that I currently have, once I add the TSI turbo? Or do i have to change the lines as well? The oil supply and return lines to turbo will work. I'm prettty sure the oil cooler from a intercooled car will work. Only issue being the fitment of the line if they interfere with the i/c piping. Cant you just keep you current oil cooler? Edited January 2, 2013 by JohnnyWadd Link to comment Share on other sites More sharing options...
flatty86 Posted January 2, 2013 Author Report Share Posted January 2, 2013 I'm not sure.... I would like to. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 2, 2013 Report Share Posted January 2, 2013 I'm not sure.... I would like to. Look around on the site its been done before. The main parts you need are the piping and intercooler and a intercooled turbo compressor housing for your turbo. Link to comment Share on other sites More sharing options...
flatty86 Posted January 2, 2013 Author Report Share Posted January 2, 2013 There is a guy I may be buying all the parts from....however I just got the car running and it need a lot of work... so my best bet is to get it running right first before intercooling it don't you think? Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 3, 2013 Report Share Posted January 3, 2013 There is a guy I may be buying all the parts from....however I just got the car running and it need a lot of work... so my best bet is to get it running right first before intercooling it don't you think? Sounds good. Intercooling it wont hurt though and its a good excuse to get under the hood you might find some vacum leaks while you there. Link to comment Share on other sites More sharing options...
shift1313 Posted January 31, 2013 Report Share Posted January 31, 2013 I did a post with lots of pictures when i did the conversion. I did all the stuff and as soon as i did i was having bad boost cut issues. I still have all the parts on my car but put it back to Non IC. Id sell you everything if you want with the note that one of the hoses for the IC from a fatty didnt fit since i mounted it at an angle and thats probably where the leak is. I cleaned the IC with MEK(nasty stuff) so it should be clean/no oil... here is the post if you want to follow it. http://www.starquestclub.com/forum/index.php?showtopic=76827&st=0 I did things a little different because i didnt want the IC hanging below the bumper. Link to comment Share on other sites More sharing options...
shift1313 Posted January 31, 2013 Report Share Posted January 31, 2013 ps, i don't get onto the forum very often so if you are interested in the IC(which i have to pull off my car) just shoot me an email. solidworkssurfacer at gmail.com Link to comment Share on other sites More sharing options...
flatty86 Posted February 3, 2013 Author Report Share Posted February 3, 2013 not sure if i want to buy ine that you had issues with. 1 Link to comment Share on other sites More sharing options...
shift1313 Posted February 3, 2013 Report Share Posted February 3, 2013 its ok. its less hassle for me leaving it on the car. im 99% sure my issue is with the hose i used to go from the IC to the hardline through the core support. It was missing when i bought "all the IC piping" from another member years ago. I grabbed the closest thing i could at Advance Auto but it didnt line up and i think leaked. Also i mentioned a slight tear at the turbo which shouldnt matter as much since i was reading boost at the TB. I think the 84 EFI system was more sensitive than the 86 to overboost. If you change your mind let me know. I would do $100+ shipping if it helps you out. Its the turbo compressor housing, waste gate, my brackets for the IC, parts to move the oil cooler, IC and all the piping I have. The waste gate is an 88/89 3 port one because the bolt pattern of the Non IC wastegate doesnt fit. You could find a 86-87 IC waste gate thats single port or use the 7.5 or 10psi side of the 3 port. Either way when i finally get around to building my motor im going to run nonIC cause i like how fast the boost builds. Mine will be a driver so it will be higher compression and stay lower boost to get the most bang down low. Not interested in High boost on this car anymore. im racing motorcycles and i have a new baby so i have even less time for this car than normal... 1 Link to comment Share on other sites More sharing options...
