Nightcall Posted October 25, 2014 Report Share Posted October 25, 2014 Hi guys ive been cleaning and flushing my radiator of rust. Prior ive new sparks wires dist and cap. I left prestone flush + water in rad. I drove it a bit like instructed (5 miles) and entire ebngine bay is steaming and im overheating. Why?. Next thing i know my car wont start. Can you give me your opinions? Thx Link to comment Share on other sites More sharing options...
chassispuke Posted October 26, 2014 Report Share Posted October 26, 2014 u might have purge the cooling system and your fans arent turning on. Link to comment Share on other sites More sharing options...
TexasQuest Posted October 26, 2014 Report Share Posted October 26, 2014 I wouldn't leave anything in the cooling system except water and antifreeze. Get that Prestone flush stuff out of there and refill with coolant. Link to comment Share on other sites More sharing options...
Nightcall Posted October 27, 2014 Author Report Share Posted October 27, 2014 Hm ok. It still needs to be flushed tho. Brown water still coming out when i drained it. Is it ok to add coolant? Link to comment Share on other sites More sharing options...
Nightcall Posted October 27, 2014 Author Report Share Posted October 27, 2014 Also it cranks but wont start. Its not completely dead. Battery is new so im not sure whats wrong Link to comment Share on other sites More sharing options...
station Posted October 27, 2014 Report Share Posted October 27, 2014 Take radiator out and use a hose to flush it out forwards backwards upside down etc etc.You could've disturbed coolant sensor or ballast resistor in front of rad? Link to comment Share on other sites More sharing options...
Nightcall Posted October 27, 2014 Author Report Share Posted October 27, 2014 (edited) Take radiator out and use a hose to flush it out forwards backwards upside down etc etc.You could've disturbed coolant sensor or ballast resistor in front of rad?Where is the coolant sensor (did you mean thermo sensor?) and ballast resistor located? I don't think I've disturbed it. I will take the advice of taking it out and flushing it though. Thanks Edited October 27, 2014 by Nightcall Link to comment Share on other sites More sharing options...
station Posted October 27, 2014 Report Share Posted October 27, 2014 Thermo/coolant sensor is right next to the thermostat housingBallast resistors are below the bonnet shut catch (mounted in the centre). Link to comment Share on other sites More sharing options...
markhansenconquest Posted October 27, 2014 Report Share Posted October 27, 2014 (edited) look inside rad..... cap off ...are the flutes open ???the ones u can see are they plugged up ??....u may need a new rad...u can get a alum on ebay for 230bucks and its plug and play.....best rad for your quest............... Edited October 27, 2014 by markhansenconquest Link to comment Share on other sites More sharing options...
TexasQuest Posted October 27, 2014 Report Share Posted October 27, 2014 You should flush the cooling system until it is clear, no brownish color. I would backflush the cooling system thru the heater core too. No telling how much crud has built up in there over time. Link to comment Share on other sites More sharing options...
SFBMX88 Posted October 28, 2014 Report Share Posted October 28, 2014 These cars don't have ballast resistors. The no start could be coincidental. Do you have spark and fuel while cranking? Link to comment Share on other sites More sharing options...
Nightcall Posted October 28, 2014 Author Report Share Posted October 28, 2014 other than the obvious...how to tell if you have spark? I have new sparks and wires. Link to comment Share on other sites More sharing options...
station Posted October 28, 2014 Report Share Posted October 28, 2014 Take HT leads from spark plug, hold end against earth (ie engine metal), turn engine with key and look for spark arcing from HT lead to engine. Link to comment Share on other sites More sharing options...
station Posted October 28, 2014 Report Share Posted October 28, 2014 I thought the injectors received the power from ballast resistors? The two I've had have had them http://forums.austarion.com/viewtopic.php?t=6344&highlight=&sid=e8633b73916baeac532c2644bc41f1c4 Link to comment Share on other sites More sharing options...
SFBMX88 Posted October 28, 2014 Report Share Posted October 28, 2014 (edited) Does it crank and not start/fire? Or does it not crank at all? That resistor set under the air cleaner is to reduce current flow to the Starions low impedance fuel injectors. Without the resistor, the injectors would burn up. Ballast resistors are used on vehicles with a points type ignition system, something our cars dont have. To check for spark, you can have somebody crank the engine over and use a 12v test light: You can also pick up an adjustable spark tester: http://www.oemcycle.com/image/Adjustable_Ignition_Spark_Tester-900459826.jpg or pull a spark plug, connect it to ground, and check for spark while cranking Edited October 28, 2014 by SFBMX88 Link to comment Share on other sites More sharing options...
