- 15 replies
- 2608 views
- 531 views
- 16 replies
- 1280 views
- 853 views
Idle air controller
By gofastredstar,
So Im running a FIP system that has been modded at least twice by Scott87star. While it runs good, it idles low when cold. I can pull the vacuum line off the intake manifold, the idle goes right up. So thinking I can get an another air bypass valve like the one Scott used for the boost controller. Then I could wire that up to the ECU and plumb it into the manifold, to bleed air in until a set temp. Anybody run something like this? Or can Scott step in with a suggestion? Thanks, John
Looking for MPI setup.
By MasterVivi,
Hey guys. Please contact me if you have an MPI setup for sale. (760)807-8342 Cash in hand. Thank you. Jeff
my car is alive again! thanks Joe!
By Bills89quest,
http://vid204.photobucket.com/albums/bb148/4cylfury/Mobile%20Uploads/20150406_124001_zpsshmvjpfk.mp4
Sunroof wind deflector hinges needed
By pcristquester,
Mine have broken where the plastic connects to the metal pin. I don't care about surface flaws as i'll be refinishing the metal parts. I don't need the deflector itself, but will take it if you don't want to separate them.http://i1372.photobucket.com/albums/ag335/pcrist/009_zpsuaa6wubu.jpg
