- 1495 views
- 12 replies
- 858 views
- 4 replies
- 503 views
- 415 views
Interior out...questions about rust/holes
By vanillagorilla,
I took out a good portion of my interior the other day. No carpet on the floor. I noticed my passenger side floor drain plugs are completely rusted it. Should i keep the functionality of these and replace them with good ones, assuming one could even find them, or just cover up the holes and keep it moving? I purchased this car already with an engine swap and i can see several holes about an inch long on the trans tunnel. I assume i should try to get this patched and not just cover th
Should I pull my head?
By D-VO,
So here's the story, you can check out my thread in the restoration section, but I've been tearing down stuff in the engine bay, and I'm at the point now where I have a head / block left... My question is it worth it to just pull the head off at this point? Pros: I can do valve seals, valve guides, and headgasket. I know the seals on 2 and probably 4 are gone based on spark plug conditions, I get a big white cloud on startup. I can inspect the cylinder walls. I will feel a lot better about 1
86 boost sencer
By markhansenconquest,
30 bucks shipped...can email pics...just need email address...............
5 Pole Relays for replacement or relocation
By JohnnyWadd,
The metal relays to the side of your battery can be replaced with these OEM pieces from another Chrysler car. I have 4 extra ones. Yours for 15 shipped. All tested and working. To use these you free the prongs from the plastic relay box and toss the box and then install the new plastic relay. These are much more commonly available than our crusty metal ones and good to have just as a spare for testing the car. http://i1187.photobucket.com/albums/z388/starionkiller/parts%20for%20sale/th_S
