    Question about Cosmo and Tokiko
    bha280
    By bha280,
    I bought some dual-spring Cosmo coilovers and am wondering whether the helper spring goes on the top or bottom. The instructions say helper spring, washer, big spring; but is that the order from top to bottom or bottom to top? Second; I also bought Tokikos all the way around but, looking at them compared to the stock ones, they don't seem as big around. Does the housing they slide into extend up past the spring perch? It looks like there is some kind of nut holding the stock inserts in place. Th
    Is anyone using Schneider's 296 roller?
    chiplee
    By chiplee,
    Grind Number: 296RH-14 Intake Duration (gross): 296 Exhaust Duration (gross): 296 Intake Duration (.050”): 240 Exhaust Duration (.050”): 240 Intake Valve Lift*: .488" Exhaust Valve Lift*: .488" Lobe Separation: 114 Intake Valve Lash: .000" Exhaust Valve Lash: .000" RPM Range: 3500-7500   Starting to have enough spare time to ti
    Oil pan and fuel pump bracket
    Jimbotsi
    By Jimbotsi,
    Local pick up is preferred within an hour of 08086 NJ. Damaged pan is OK all I need are the oil separator return and dip stick tubes to weld onto a truck pan so I'd prefer local and cheap.
    giving up
    starquestaz
    By starquestaz,
    http://phoenix.craigslist.org/evl/cto/3191404955.html   $1700 for car with 109k original miles... motor had new head put on around 90k and timing kit bse kit arp head studs etc   no turbo or exhaust manifold   stock intake   everything is disconnected pretty much   original paint   16x9 rears   short shifter 5spd manual     giving up on the starquest sorry guys
