- 31 replies
- 3391 views
- 6 replies
- 724 views
- 6 replies
- 657 views
how many of you
By Shelby,
just curious have you ever noticed the heat waves radiating from your body ? I first noticed it while having a hangover many years ago , if you have your eyes focused just right you will see the body heat radiating from your hands , arms and other parts , it depends some what on the room temps , cooler room temps makes it show up better and back ground makes it harder or easier to see with practice you'll be amazed at what you are able to see it looks like your on fire and the fire is i
Fuel pump replacement
By station,
I'm wanting to swap the fuel pump for a Bosch 044 type, and want to know which terminals/connectors I'll need? I'm connecting to the immediate fuel pipe (to the fuel filter/engine) using a barb connector that should screw onto the 044 fuel pump. I have no idea on sizes so not sure which one to get. I removed the old one as it seized, but I got it running. It needs a tap when it's left for a while, so it needs replacing. The damper on the end is shot (but somehow manages to not leak yet):
Happy Birthday "PDodson"
trying to cleaning paint off starion tail lens...
By markhansenconquest,
So when I was looking for parts for my 86...I. found a 86 at pick apart in S/diego So I bought the tails lens,,,but P/owner spray painted the car black and over spray on the tails...tried nail polish remover and thiner.. ( but ,,not working very good.) Has anyone had this problem...??? and what did u use to polish the paint off???.....
