- 6 replies
- 1179 views
- 4 replies
- 1126 views
- 903 views
- 7 replies
- 1378 views
Looking for a stock wiring harness
By 84germ,
Just picked up a stock 84 quest and the previous owner cut a bunch of wires out. Anyone have a stock wiring harness around they are willing to get rid of?
How Do I Remove Cam Plug?
By Contsi,
In the middle of replacing valve cover gasket. Looks like 2 bolts under valve cover needs to be removed.
Thanks
Fuel pressure regulator
By MarkA,
Hi, My fuel pressure regulator is leaking, can anyone point me in the right direction of where to buy a replacement? Thanks
Fuel Pressure Dropping
By FieroGTFan,
Hello all! Had the car out today (not driving nearly as much as I would like) and on the way to work, about 5 miles, the car ran great and felt strong. On the way home I noticed pulling out of the office that it felt a bit sluggish. Checking my gauges it appeared that fuel pressure was low (~35psi), normally the car is set to run 43psi.
Thought it might have been a bad reading until I saw the air/fuel was also reading lean. I kept the car out of boost to get it home, but when on the throttl
