kwak
Everything posted by kwak
  1. OK, that worked also. The thread I saw the problem in, http://www.starquestclub.com/forums/viewtopic.php?t=8881 I now notice has problems with coding used in the previous version of the site. Never mind.
  2. That worked. This quote is from using "Reply" then the "Quote" format.
  3. This first reply was using the "Quote" button in the main thread.
  4. I've seen other thread where quoting with the new software does not display properly. So I'm trying it out here. Next reply will be with a quote.
  5. This is a very low priority bug. People without an avatar have a small white box with a red X displayed for the picture. Nothing should be displayed. edit: I forgot to add, the site looks good!
  6. Thanks, I'll give those a try. After I initially got the engine to start I just never fiddled with what I had done to get it better.
  7. Wow, after months of searching I finally found people running TEC2 on these motors. A couple of thoughts from what I've read in the thread so far... I'm using the TOG and IOT generated by the WinTec2 wizard. The diagonal of my VE table is zero. Above the diagonal is positive numbers and below are negative numbers (Correction view). These were figured from looking at the logs and seeing how much EGO correction was being applied. Keeping EGO correction near zero lets this correction respond faster. From the wideband sensor at the dyno mine likes AFR of 13:1 with stock turbo at 14 psi on 92 octane. artinist, thanks for posting your calibration files. I'm interested in looking at them. Two comments from artinist's tuning tips list: a. For drivability tuning, another possibility it to just ignore the first one second of acceleration in the logs since that is when acceleration enrichment kicks in. b. I don't understand the 70 setting for VE at all. My VE table is based off of reading my logs (EGO correction) and changing the VE table so EGO correction is near zero. I did a lot of acceleration tuning and mine is pretty good with minimal EGO correction. What are you guys using for startup enrichments?
