Acselor
Everything posted by Acselor
  1. I have a 5th fix that took me about 6 hrs of laying under the steering wheel with my legs sticking out the door to figure out. if i had pics i would show you cuz its kinda hard to explain but ill try to explain as best i can. all the other fixes never worked for me i dont know why so dont ask. except for welding i didnt wanna try that. after taking the panel above the pedals and the panel below the steering wheel off i began to devise other stratagies to fixing this. I eventually took out the very bottom cotter pin and and pulled the arm off (you'll understand better if your looking at the setup). Now the setup doesn't work at all. but if you press it in to the locking position and then use your fingers to push the very very tippidy top arm up it should get real snug and hard to move the steering wheel. now thats just to show you how it should be or how mine was. I think mine was kinda worn out anyway. now what i did was pull down on the middle arm to unlock it then pull out on the tilt steering knob itself (if you don't do it in that order it wont unlock). Now that very bottom arm is free and can be moved around so i tried resting it on top and to the left a little of the old pin it used to rotate on. i got a small screwdriver likle a stubby or something and put it in the hole at the bottom of the arm to hold it in place, then i pushed in on the tilt steering lever. It should lock better than before. ( i dont know mabey this only happened to my car ???). if yours locks completely which mine didnt in this spot then this is where you need to stop and skip down some. for those that didn't, keep reading. Like i said mine didn't lock completely so i tried a different spot which became difficult because i had nothing to rest it on while i locked it. I unlocked it either by holding it down tight with the screwdriver and pulling the knob out or pulling down on the middle shaft (watch your fingers its a great pinching space). I then moved it up the left side a little bit so it was no longer resting on the old pin. i held it in place with a srewdriver and locked it, to my surprise it locked tight i could pullmyself out of the car with it . if yours doesn't lock there i dont know what to tell you this is as far as i got i am assuming try different positions. Now you have to drill a hole through the original hole on the bottom arm in the place where it locked best for you. (use the hole in the arm as a guide for where to drill through the piece of metal behind it and watch out for wires behind that). after the hole is drilled i just grabbed a small bolt and some nuts that fit it from a bucket downstairs and bolted it on but leaveing enough room to spin. if it doesn't lock all the way dont force it. i had a problem after i got it bolted in because i could get the exact same spot that i had before. So mine doesn't lock completely if i push the steering wheel all the way up but if i move it down slightly and then try to lock it, it locks just right and doesn't move. I am warning you though if you happen to screw up and drill the hole in the wrong place there is no second chance, theres just no room for 2 holes so make the first one work(or youll be stuck with it back in the orginal spot). i would also wait for me to give mine some time. if something goes wrong i definetly dont want it to happen to a bunch of others too. feel free to ask any questions except for pics because i dont have any, i can try to explain it better if you have a specific part you dont undrestand. i hope this helps and i hope no problems arise.
  2. I dont know if I was just the unlucky one or if there is another post somewhere else about this company but i had a particularily bad experience With Eric the owner of St. Andre's Auto. I had ordered a $320.00 HKS exhaust system from them seeing as how they were the cheapest i could find. My credit card was charged but i never got the product. i figured mabey since it was not a item that would be readily available so i gave it some time. Before i knew it almost 1 and a half months had passed. I almost forgot about the exhaust i had other things to do on my car. I began calling them. The first day eric was not in and wouldn't be back till a week later or so. For some reason Eric was the only one that could help me, Why is beyond me. So i waited a week and called back and he still wasn't there. Eventually my father called (he is more intimidating and knows what hes talking about). After going to the Better business bureau of somewhere in Cali online and calling the attorney generals office we find out he has had numerous complaints about things not arriving and other such thing. He has been in and out of court numerous times has an Alias and even sold some guy a business that was supposedly a franchise but turned out not to be and swindled him out of $150,000.00. Eventually Eric called me and he told me he was tracking it now and he wasn't even open yet, only problem was i didn' want the item tracked i wanted the item yesterday. In fact i didn't even want the item anymore. I told him i wanted the order canceled and my account credited  and i didn't care if it was a special order i wanted my money back. Well turns out my account still hasn't been credited and the credit card company i guess will have to go after him. I ended up buying an exhaust system from Rockauto.com i like them. All my parts have arrived on time. the car is now on the road and rdy to be registered and inspected. Thx for listening/reading this post and plz beware of St. Andre's Auto.
