eldos
Keep the turbo spooled!
eldos's Achievements
= Update =- Intake - Sold - Tim_C Turbo T3/T4 -Sold. Thanks All! Any interest in the other parts? Steve
= Update =- Intake - Sold - Tim_C Turbo T3/T4 - Pending. Steve
-= Update =- Intake - Sold - Tim_C Turbo T3/T4 - Still for sale. Take a closer look at how big it is compared to the pop can.
-= Update =- Intake - Pending Turbo - Still for sale. Other stuff I have that I am willing to sell MSD DIS2 w/ 91 Eclipse coil pack (Waste spark ignition set up) 86' flat side 5 lug wheels and tires Transmission 88' ECU and knock box 88 Injectors TEP Craler street cam
-=Update=- Turbo- Still for sale Intake - Still for sale Steve
Turbo- Pending - Intake - Still for sale Steve
Chads Intake $750+ shipping + 2mo wait MSD injectors $93.70 each + Shipping (Summitracing) TB was $55 + Shipping Extra fittings $25 Pressure reg $50 (Bosh Adjustable w/ boost) Thats around $1250 So $800 is good Steve Aurora, CO
As of right now, BOTH are still for sale. Steve
And you don't need to wait 2mo. for it to get built. :wink: Steve
It was a converted stock manifold by top end. Has stress cuts between runners, so there is less chance of it from cracking. It now takes a Garret type turbo mount. It was also ported out by them for better flow. Steve
Here is the story. Had the Turbonetecs T3/T4 (Topend kit) installed and ran great! Later, started to run PIG Rich. So, I wen't for a MPI setup with a computer. Found out that what happened was that I riped the inter cooler open at one of the mounts. Got "Chad's intake", Mustang TB and Injectors. Never could get my computer to take the timing right, so never ran it. Now I am parting it out cheep. Don't have time because of work for this car. Picture of the parts http://www.esnips.com/web/Parts4sale Chad's intake w/ MSD 72 lbs/hr and Mustang TB $800 shipped in US. Turbonetecs T3/T4 Internal w/ MAS, intake Pipe and old K&N filter $800 Shipped in US. Thanks, Steve Aurora, CO
Any tips to geeting a good seal on the injectors for chads intake? I am using mustang O-rings on the injectors and e clips on the injectors for the fuel rail to rest on. I have changed the number 4 injector O ring 2 times and still leaks. Steve Gee
Hey folks, I did some digging in a local yard and found a distributor from a 90 Galant 4g63 SOHC (2.0) it was about 1/4" ish longer than the stock distributor. The shaft seems to be the same diameter at the top ECT. So you might need to shim it a bit. The top seems to be a bit taller than the stock, so if I was to use it with Chad's intake, I would have to use it for timing only. The cap would interfere with the intake. I am not sure about interference with the mega. This also has 4 wires going directly into the distributor in the bottom. The color code seems to match with the colt diagram above. I also found a shorter tower distributor in a 91, but the nut was frozen and I did not have a good box end wrench with me. I was un-able to get it out, but it uses a flat connector to the base of the distributor tower. It was also a 4g63 SOHC. I also found one like the first in a Hyndi. The 1.5,1.8,2.4 have the coil integrated into the to of the cap. A possible way to go if you want to use that coil. Steve Gee 88 ESIR
Check it out.. www.efi101.com Steve Gee 88 ESIR
Could I use a magna or vista distrbutor for a cam sensor? Do they have a #1 reff? Steve Gee 88 ESIR
