Starheel
About Starheel
- Birthday 01/05/1985
Chapel hill, nc
27516
ESI-R
1988
Auto
Valencia Gold
966 profile views
Starheel's Achievements
Yes, still available. I will also PM you.
I will keep you guys in mind but I am really trying to sell as a package right now.
http://i982.photobucket.com/albums/ae309/mjomorgan/7B0456D7-F673-42B1-9F1A-FA53E6F49732.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/B47A0D14-8F1F-420F-847A-BE20AA92CA29.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/09CCF42B-E8ED-45FF-98AC-6D1DB61D7714.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/001C0494-1CB1-4027-AB25-6631017942C3.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/820ED3ED-095F-433D-B262-6A334FC557DD.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/9A9C9ABF-E950-4D15-8008-340F3ED3976B.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/27107189-7F7C-4CEF-9E0A-AA18669B0605.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/7483118D-F5CA-49F8-82F8-88126992F922.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/23DEB63F-9EDA-4836-A2C0-AB6DC1B37730.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/4B0323E1-901A-4B04-AF14-2C94F5957BB4.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/6248B307-32F5-4285-B4E9-5E42D1DF7835.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/2E8EA412-01CD-4AA0-9A99-7D36A2D9E1AE.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/0D0E217F-4BA4-4039-9B9C-2C299D56D2CD.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/7FB20436-2FC6-44B2-B747-0A97484CAE33.jpg
http://i982.photobucket.com/albums/ae309/mjomorgan/383E1A92-F66E-4598-9068-4C8F04D5267E.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/00814379-E4FE-4826-A08E-1E0BD6848E8F.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/B6B3FC39-E708-4914-9F2F-3146C7CD30ED.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/3274C070-8392-4041-964C-19DF989F067F.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/6E541084-0333-4543-AF78-C8B9142334E9.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/EE08B050-3EF0-4F06-B7A3-F341E4554BF3.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/798A5BE7-137D-42B8-B121-2A10879C6034.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/34A2DAF8-E058-45EF-98AF-2E45E5FEEA76.jpg http://i982.photobucket.com/albums/ae309/mjomorgan/6A798D28-EAEF-4517-9E02-19F846321485.jpg
OK, bought a house now need to furnish it. I have a 1988 Starion auto 88K miles rebuilt 10K ago by previous owner only 2 spots of rust, see pics needs paint and sunroof perimeter alpine radio with 10" sub slotted disc brakes adjustable coilovers no a/c, has rough looking a/c compressor but no belt. heat works great. ran great until 4K RPM where it sputtered. I started taking it down to find the problem and never got it all the way back together. while i was searching for the problem i got the injectors tested, said they were fine, new fuel filter and cleaned in tank and in line cone filter, changed oil to mobile one, changed trans fluid and filter, new distributor, new plug wires, i upgraded the throttle body with lower shores machined throttle body, added a fuel pressure gauge on the fuel rail, egr delete, cruise delete, opened up the air filter housing, upgraded the tps, and added a boost gauge in the factory location. Got everything together and stripped one bolt keeping the throttle body on the intake also noticed that one of the injectors doesn't hold the pressure, but fuel pressure while turning over is right on. So to get it running with the installed accessories would take re-tapping the intake, refilling the coolant, and re-connecting the vacuum tubing including the boost gauge. extra parts: couple extra untested injectors tail lights, small barely visible crack lower shores brand new head with OE size valves and valve job, 100# springs and 1.6 roller rockers extra cam shaft, stock extra computer 2.5" hard OVCP with BOV and turbo to intercooler pipe 3" turbo back exhaust with magna flow muffler, and crack around flange at turbo extra 3" down pipe that doesn't match with the turbo back system 16g turbo with port matched and stress relieved manifold AEM A/F ratio gauge 3" GM MAF and MAF translator extra fuel rail two intake manifolds, one bead blasted with new sensors in it o an m manuals MITSU OEM tester no plugs I know im forgetting some stuff, but i will update. have title in hand. I would like to sell as a package at $3500obo I have access to a trailer and could deliver within 3 hours of Chapel Hill, NC http://i982.photobucket.com/albums/ae309/mjomorgan/3901A100-E352-4861-9BBB-5D2477BB41E0.jpg
A new intake manifold? I have one, but was trying to avoid having to take off the manifold as it is a complain to get to all the bolts.
So i took my throttle body off to change upgrade my head. Realized that was going to take longer than i thought on my work schedule, but decided while it was off to get an upgraded throttle body from BrianPaul. I also got a upgraded TPS. anyway I put the throttle body back on but the last bolt to go into the intake for the throttle body to intake connection stripped. does anyone know this size so i can go in there and re-tap it? I want to get this thing back running so i can go get my exhaust put on and my 16g turbo
Also interested, but of course im out of town from the 8th-17th.
Forgive my ignorance, but how much of the ATF? and will that not effect anything if it does leak down past the rings?
Hi, My name is natallica....and I'm an addict! The wife's 89 SHP
Starheel replied to natallica's topic in Just plain ol' B.S.
did you have the interior re-done? the first pics show slashed seats but that second one... if you did, are you willing to say where and how much? I will be needing mine done in the near future. -
I want the single din radio with pocket and gauges. Can you get this non aluminum? Just asking because I want more of a stock look. Or should I just paint the aluminum?
I have a 3" downpipe but would be willing to go on a full 2.5 " if someone has one. Local shops have quoted a lot of money, so i have debated getting the mookoh 3" cat back on ebay but thought i would try here first.
Intake manifold PM'd
how much for the intake manifold to 27516? im assuming the 87 and 88 are the same?
and in concord? I will be in charlotte this weekend if that helps any.
