Right, after doing a few searches and a bit of reading of your awesome forum, i've come to some conclusions, and i'd like to know if i've got my story straight. 1: You can use MR2 Front KYB AGX adjustable inserts in the front of a non-SHP starion if you either insert a 1.875" spacer first, or shorten the strut by 1.875", as the MR2 insert is shorter than a factory starion insert. The same applies for a SHP starion, but you must remove the original adjustment dial and weld on a patch. 2: You can use the MR2 Front KYB AGX adjustable inserts in the rear of a starion if you have the SHP struts, with removeable inserts. This also involves removing the original adjustment dial, and welding in a patch. The same as above also applies, with either using a 1.875" spacer, or shortening the strut by 1.875", as the MR2 Front insert is longer than the factory starion SHP rear insert. 3: You can use the MR2 Front KYB AGX adjustable inserts in the rear of a non-SHP starion if you cut open the strut and weld on the top of either a SHP strut, or a front strut. This will give you the retaining nut on the top of the strut, which makes the inserts replaceable. While your doing this, you would also shorten the strut by 1.875" as the MRS Front inserts are longer than whatever is in a factory sealed starion rear strut. Oh god i hope i have that right, hah! If i dont, please set me straight. Cheers guys, its hard getting info on this down under, as there arent many people with starions willing to experiment! Zac.
