Munra
Everything posted by Munra
So I should replace it?
Tearing some stuff off the car last night I noticed that this doesn't look right, Just wanted to confrim. http://anbservers.net/files/images/conquest/IMAG0142.jpg
Here are some pictures of the injectors but I am pretty sure you guys already know what they look like.
Umm. I have an 87, Good infomation.
I am a newbie when it comes to anything with my conquest. I know I had fuel system issues because the car sat 8+ years with fuel in it. Almost every post I read here said send the injectors RC Engineering. I did, and like to show other newbies the information you get after they return the injectors. Now I wish I took before pictures, but I didn't but they look brand new now. I will post the after pictures this evening. Also any experience users who can comment on what is the most important information on these tests, would be helpful also. RC Engineering-Green.pdf RC Engineering-Black.pdf
Thank you very much, that worked great. I get the injectors back from rc engineering tommorow. So I will complete the rebuild of the TB . My next line objective is rubber hoses. This car sat for atleast 8 years maybe longer. The hoses are brittle and well crap. What hoses do I have to replace and which can I just remove and plug? Would the parts manaul have the size of hoses that I need? Assuming ruber hoses and clamps would be easy to pick up at any auto store.
hey thank you Is there a good post on how to test the injectors to see if they work befor I send them to RC fuel injection for cleaning? Couldn't find anything on the forum search.
Hey guys, I bought this car almost a year ago and things have settled down enought for me to start working on it. For the most part this car was complete. I tried starting it right of the bat didn't start but it atleast turned over. The fuel pump was bad so that was replaced. I tore off the thorttle body last night and started to tear it down and rebuild it and to also replace all the screws with hex head bolts/screws. I will also send the injectors off for cleaning and testing. I also just ordered new plugs (NGK 7031) and new wires. So I think I got a good start. My first questions are pretty simple. I tested the compression last night, I think its fine (As per reading some topics after a forum search) but I am not 100% sure, cycldiers read as follows 1-120 psi 2-113 psi 3-115 psi 4-118 psi
There is a Iphone app for the Forum http://itunes.apple.com/gb/app/ip-board-communities/id372597645?mt=8 Works on all forums that use Invision power
oh I fixed that should see it now, If want to still use what you are using now I am sure I can come up with instructions on how to add a link to the nav bar at the top after chat.
Here is the easiest way to do this http://community.inv...070-member-map/ Its a free addon for forum that allow members to add locations. I have used it before for my own forums. Let me know if you need any help I just got a conquest and I am sure I will need all your knowledge the least I can do is help and share some of mine with IPB. Here is an example of it on my site http://anbservers.net/forum/membermap/ (I don't mean to advertise but its easy example for me to show) I am still running an older version of IPB but it will work the same. (Any bugs you notice are because of the skin and not the app)
I Purchased this car, Bringing it back to life.
