aruggs15
Everything posted by aruggs15
Are they good ?
so basically all there is , is the hydraulic rollers then ? then my question is if I'm putting a bigger cam in it like a schneider 296 roller grind what is everyone setting the installed valve stem height at ? or is there enough travel in the lifter to make up the difference ?
there adjustable roller rockers can I see pictures ? used or new ?
does anybody have or know where I can get a set of adjustable roller rockers ?
Im looking for some roller rockers, or if anyone knows what the target vehicles are or where i can find them brand new info would be appreciated.
ooo thats the other thing forgot to list it was smashed in the end so the whole front clip is toast all the way to the rad.
the wheels on it aernt stock i dont beleive its shp but ill look, center console,floor pan plugs, and the door hinges i think its all there ill also look and no its a manual
hey guys i got an 87 red and rusty engine trans and rear end are gone, some engine parts left let me know wat u need
the seat belt is all the way back or "fastened", on my dash my door light comes on when i open the door ?
ok i just dont get it, started testing stuff with my power probe i checked to make sure the motor wasnt bad which it isnt, so i thought maybe the limit switches were stickin or somethin cleaned those, same problem passenger side works fine drivers side doesnt, wat else could it be ?
i got an 88 ecu but i dont have any of the other parts
i hope its the wrong pcv valve ... where do i get a oem one ?
So i have a pretty fresh engine and recently started boosting on it and under full boost it blows the dipstick out and oil goes everywhere, the turbo seals aernt bad and i wouldnt think its blow by but i guess i just dont know what else it could be ? any help would be appreciated. thanks adam
Alright guys is there a way to put a 16g turbine and compressor wheel in a stock housing im sure youve answered this before but my turbos smoked and i kinda wanna upgrade a tad
Parts lot from 88SHP part-out: SE Michigan - $150 FOR ALL
aruggs15 replied to MI_Mitsu's topic in Parts for sale
so three hundred bucks for whatever u got ? -
yea like wat do u do ? tap the pressure galley for an AN fitting and run the line to the new regulator ?
So guys has anybody come up with a way to delete the old fuel pressure regulator and install a adjustable one with a guage on it ? any ideas and input would be appreciated.
i would be interested in the front fenders if u still have them
hey i need a timing cover and the automatic seat belt computer, its for an 89. also a knock sensor thanks adam
bsek ? balance shaft elimination kit ? i could send u that much money?
im lookin for a set of balance shafts used but in good condition, im trying a little experiment does anybody got some for cheap ?
car dies sits for a while and fires back up
aruggs15 replied to aruggs15's topic in Advanced Virtual Mechanic
... ? cone filter ? where is that at iv had the fuel system apart the only thing iv seen is the screen in the tank and the inline filter ? -
its an 89 the coil is good it still has spark when this occurs fuel is the problem -
what kind of rear calipers you got used ? and do u have the bolts to go with them ?
