Quest340
Everything posted by Quest340
87 Conquest TSI in Washington state-SOLD-Thanks Jeremy,enjoy
Quest340 replied to Quest340's topic in Cars for sale
Car sold today, Thanks -
87 CHRYSLER CONQUEST TSI REBUILT 2.6 LITER MITSUBISHI ENGINE Clearwater Non-Jet valve cylinder head-NEW Solid bronze valve guides-NEW Professionally race ported and polished Replacement rocker shafts-NEW 83 Length replacement valves-NEW Schnieder Performance valve springs- NEW Tim C’s Screaming Banshee Camshaft-REGROUND- 292/280 duration .454/.454 lift 107 degree centerline 111.5 lobe separation .006 intake .008 exhaust lash Mechanical rocker arms-USED Ajusa metal head gasket ARP cylinder head studs-NEW Replacement timing chain and gear set with adjustable camshaft gear-NEW Balance shaft elimination kit-NEW Wiesco Forged piston kit with rings-NEW Race prepped rods with ARP hardware and bronze wrist pin bushings-Machine shop prep High volume oil pump-NEW POR-15 Engine paint kit Custom fabricated exhaust manifold 4 into 1 style with T3 style mounting flange Mitsubishi TD06 17C turbo charger-USED 2 ½ inch downpipe G.M. single wire o2 sensor-NEW Rebuilt and ported throttle body E.G.R block off plate Walbro 255 fuel pump-NEW Aeromotive A1000 Regulator-NEW K&N aircleaner-NEW Custom OVCP pipe Custom aircleaner hard pipe 89 ECM upgrade-USED Replacement clutch, slave cylinder, release fork, and pivot-NEW Imron acrylic enamel paint job Repo factory style graphic Factory service manuals-USED Factory parts manuals-USED Cloth car cover-NEW I have about a truck load of extra parts I have collected over the years and many More new items that are too numerous to list, the above is the major stuff. The car was originally white with maroon interior. All the interior has been swapped With factory black interior -
I'll e-mail anyone a Microsoft word document with Mods. I really don't want to write the whole thing again here. Engine rebuild is all High performance top dollar stuff with one of a kind header with TD06-17c turbo. 250 miles on rebuild -
http://www.26liter.us/gallery/index.php?cat=10249 Click on this for a full Gallery of photos. -
How do I get my add back up? Left it up without a reply too long. My car is running good now and It has got to go. Man I don't want to do the whole thing over again.
Car is at the paint shop and need items ASAP. For my 87 TSI wide body. I need a set of mirors,no cracks, both sides white would be fabulous. and a passanger side marker. PAYPAL if the price is fair. e-mail or p.m ELSHAUG4545@MSN.COM. THanks Jason
Yes and advisable to upgrade coil
This is the 6AL. which comes with built in rev limiter, single stage not a 2 stage. Module/pill plug into the side of the control box to establish rev limit point. If you want a 2 stage you have to buy and add on which plugs into the module/pill socket and has external trigger to toggle between 2 seperate rpm modules/pills for lauch and top end controls but you stil use the white modules/pills.
MontyTSI, Yeah product registration is still there. The white pill modules for 6,7,and 8 grand are missing. I have a sack of 3000,3200,3400 and 3800 rpm white pill RPM modules.Won't do much good except for trading.If you want 2 differnt rev limits you have to buy a seperate 2 stage setup. THat uses one rpm for staging and one for top end. This only has a socket for ONE rpm module/pill.
Not sure what you looked up. The modules come in 5 packs to fine tune your RPM rev limit. They are $29 for the 5 packs. Stock it came with 3000,6000,7000,&8000 rpm modules. Probably would have to buy something different anyway.I think you may even buy them individually at Schucks or local speed shop. You can buy the adjustable rev module that plugs in and has like 10 or 12 differnt limit points for $50
http://www.26liter.us/gallery/albums/userpics/10249/IMG_3969.JPG
Used MSD 6AL. THis has the rev limiter built in. Like new, in gorgeous shape. Just bench tested today, works great. Only comes with 3000 range modules, you'll have to purchase your desired modules. This sells for $238 from Summit. Will sell for $175 shipped to your door. P.M. or e-mail ELSHAUG4545@MSN.COM. This was used for a short time on an industrial heavy duty engine for the rev limit function. Customer changed his mind and we pulled it off. Very little usehttp://www.26liter.us/gallery/albums/userpics/10249/thumb_IMG_3969.JPG
40 dollars each, I will pay shipping to continental U.S. 1g came from my old Talon TSI not hacked with pigtail. 3 inch I bought from e-bay a while back and the 3.5 inch I got from work. Was in an engine fire. A little bit warped around the connector but worked fine, We replaced it anyway(insurance job)All in working order. Cleaning out the garage.http://www.26liter.us/gallery/albums/userpics/10249/thumb_MAS.JPGDrop me a P.M. or e-mail ELSHAUG4545@MSN.COM. Paypal only please. Thanks
Fidanza and clutch kit complete -SOLD!!-Thanks David!!
Quest340 replied to Quest340's topic in Parts for sale
Sorry Tim, deal went through as planned -
Pictures are ready if anyone wants them drop me an e-mail. -
Here is the deal..I have a Fidanza 10.5 lb flywheel and a Heavy duty clutch kit I had custom made locally with a Fibertuff/Velvetouch disc. Disc is dampened and has marcel. This was in my car for exactly 91 miles. I removed because I did not like the way my car acted with such a light flywheel. Was easier just to buy a new clutch for my 87 flywheel. Lots of guys love this flywheel but few like myself liked more rotational weight. Clutch is supportive to mild to moderately high horsepower engine, how much I'm not really sure. Easy pedal pressure, slightly more grabby than stock organic friction. I can have pictures tomorrow. I will offer this to SQC members until the end of the weekend 3/11 then will go on e-bay. This setup cost me about $600. Will sell for $300 plus shipping. Drop e-mails if interested to ELSHAUG4545@MSN.COM. ONLY 91 MILES GUYS MIGHT AS WELL BE NEW!! Comes with flywheel, pressure plate, clutch disc, throwout bearing, pilot bearing, Flywheel dowel, and pilot tool.
still looking
I need a good stock shifter assembly and a decent black shift knob. Can do PayPal right away. Thanks Jason
I'm looking for stock weight 240mm flywheel. Having some vibrations and buzzing also drivability problems. Suspect Fidanza flywheel is the cause of most if not all of them. Shipping from Florida is going to be quite a bit to Washington. I'll keep you guys in mind though. Thanks
LOOKING FOR STOCK 88/89 FLYWHEEL. WILL DO IMEDIATE PAYPAL IF PRICE IS RIGHT. I'M IN WASHINGTON STATE (CLOSER IS BETTER FOR SHIPPING PRICE)MY ZIP IS 98902. THANKS IN ADVANCE. JASON
I HAVE A GOOD OIL PAN AND SET OF SQUIRTERS IF YOU STILL NEED THEM.$40 PLUS SHIPPING. DROP ME A PM OR E-MAIL. ELSHAUG4545@MSN.COM
Timing cover,not speedomabober
Still need one? How about $15.00 plus shipping.I'm in WA 98902. Should be 3-4 pounds with packaging. I can box it up and get you exact price if you want
I've got everything and anything suspension, brakes,axle related for a Flatty. Drop me a e-mail and we can figure out a price. ELSHAUG4545@msn.com. Thanks Jason
