Everything posted by monzaa
Will the stock manual. Bolt up
Soo the starion flywheel will bolt up and I got. To find a adapter plate ? Oil pan and switch the coolant ports from back to front
Norwood mn
Got my hands on 1991 eagle talon awd auto. Will that bolt up to starion stock tranny
Price on hard Pipes
Do you still have the yellow one for sale the one that doesn't run. I Live in minnesota Send pic please mitsg1987@yahoo.com
Magma MPI Used Set up $1500 to lower 48 U.S.
monzaa replied to KEVIN_TECHEE's topic in Parts for sale
I'll take the the mpi system and injectos and harness -
is this at idol ? dose it do it off idol check your ground it might be a air pocket in the cooling system
put a vacum gauge on it and see what the reading is it will tell you if your engine is good or it will tell you if you have late timming if your map reading are high check your exhaust system pos a cat problem
i have a megsqurt 2.2 looking for a base map tables to get it runnig all stock and 750 cc injectors it is just for fuel control only
what tunning softwear do you down load for meg 2.2 i have windows xp
eclipes yellow top injector are they 450 cc off a turbo?
power stering cooler, and heater hoses
monzaa replied to 19cturbo's topic in MPI/Standalone Trials and Tribulations
thanks whats up with the msd6 thats alot of money just for a tac signal
whats is the best set up for ms 1 2.2 for tach singal and will 245 cc injectors work good on a stock engine
make it out of clay like car desiner do play do rocks
if you dimple the inside of the runners would you start have a problem with carbon build up ? from the pcv system
