QuadCites
Everything posted by QuadCites
Price Drop 1987 Starion ESI-R $2500 Davenport, Iowa
QuadCites replied to QuadCites's topic in Cars for sale
bump for another -$250 $2500 -
...and Down it goes. Bump for -$250 $2750 -
Bump for price drop. I had it listed for $4000. -
Price reduced to $2500 firm. $3000 is what I paid for it and I put $2500+ into it. It's located in Davenport Iowa which is a 2.5 hours drive west from Chicago on I-80. Pictures are here:http://www.electracode.com/starion/101K milesIt really is a decent car and runs well.The Good:I had the transmission rebuilt last year with new syncro kit w/ master/slave cylinders. Less than 200 miles on it.New Mookeeh Performance Gas Filled Rear StrutsNew Mookeeh Performance Gas Filled Front StrutsNew Mookeeh Performance Front Camber PlatesNew Mookeeh Performance Rear Non-Pillow Ball Type Camber Plates I rebuilt the front Calipers.New Rear CalipersNew Rotors,Pads all aroundLast owner installed a new Bronze Stage 3 Clutch ....I put on less than 400 miles since I got it.Replaced rear cross member.Fixed Emergency brake Car has upgraded 3" exhaust, but the rest of the car is stock. Sounds Powerful. This car will throw your head back.Power Windows and motorized headllights work.New Battery last summer.Turbo works greatBlack Leather Interior is pretty decentNo Rust - it was a florida car until I had it shipped to the midwest a couple years agoThe car is fast.The Not So GoodAirdam is chipped1 dime-sized blemish on the hood..... see pics. 1 dent above windshield -primer exposedThere is some paint peeling on the plastic air deflector that wraps around the back window, but the primer is in good shape. -see picsThe top of the back seat has sun damage - see picsIt has a new A/C compressor, but I couldn't get it to work via the control unit. I tiried another control unit/panel, but no luck. I have 2 other sets of controllers for those who wish to try it.Drivers automatic seat belt is stuck closed.Missing the rubber seal around the sunroof....sun roof crank defunct.No antennaNeeds passenger side wiper blade.$2500
My rear crossemember bushing are non existant. Shipped to 61273 Thanks
I don't recall this particular leak before the transmission work. Leak Behavior Details: When cool, the leak stops. It happens after the car is shut off.... not right away, but about 30 seconds after and then drips maybe 30 times then stops. After initial inspection, the mechanic thought it was oil and not trans fluid.
I had a new syncro kit installed and slave/master cylinders put in. It's a joy to shift. The car is being looked at right now. I'll post the findings when it's fixed..... or if it's for sale
Good point... There has been a lot of dripping, but the oil level still seems ok. I'll check the trans fluid, but I'm not absolutely sure how to tell the difference by inspecting the puddle.
Thanks - that is going to happen today. I'm just concerned that I'm gonna get charged for a seal that wasn't bad to begin with (no previous leak). I wanted to be prepared with as much knowledge as I could. A seal repair means they're gonna drop the transmission again which means $.
I just had the transmission worked on and now there is oil leaking. Its dripping off the very front of the transmission (lowest point). Does this sound like a rear main seal problem? Could it just not be seated properly or can the seals go bad after being opened up? Thanks, Jamie
Hi JW - Regarding the wind deflector. Are the little springs in good shape? How much do you want for shipping? Would you have any more sunroof parts? Outer Seal, Crank Thanks, Jamie
Sorry about the delay getting back to you. Looks like all they needed was a syncro kit and a mount. Hang on to those parts though, they'll be there weight in gold one day. Thanks, Jamie
Thanks much- I'll let you know Tuesday what's what. Jamie
Hi mstig - Mines an '87 starion. Where in Illinois is your old trans? The mechanic is going to pull my existing tranny and open it up and on Tuesday he'll let me know what I need. Jamie
I'm in Illinois - Near Moline. I'd be interested in the parts or the used transmission. The previous owner said they installed a Stage III Bronze clutch. I assume that's a performance upgrage, so I don't know if I should just put in a used or fix the existing. Thoughts? Jamie
The Mechanic said I may need a couple of gears and a syncro kit. Where can I get transmission parts and/or rebuild kits? Thanks
$900 for an air dam is expensive and I didn't buy it, but it is original factory painted stock which certainly adds to the price.....try this place: http://www.starionpartsfactory.com/bodyparts.html The air dam is a different style, but a lot less expensive. It'll still cost a penny or two to have painted. - MOOKEEH PERFORMANCE TURBO STYLE FRP FRONT LIP $239 - MOOKEEH PERFORMANCE 83 TURBO STYLE FRP HOOD $279
Here is a great part source. She's helped me before find parts for my RX8 and now for my Starion. yuki@japanparts.com Just ask for the diagram for the area of the car in which you need parts and she'll send you that diagram with the part numbers. Email her back with the part numbers you need and she'll send you a shopping cart link like this: http://www.japanparts.com/db/partslist.php?KEYWORD=&dealer=&car=&middlesmall=&maker=&VOLKEY=aprjamie-a187a-&submit.x=0&submit.y=0 She was able to find factory air dams in the original colors, The sun roof crank mechanism, and a sun roof outer seal for me. The parts are very expensive, but if you absolutely need it.....
Thanks for the info Metric - Are the 1 piece / 3 piece air dams interchangeable across all the Starquests?
I bought these new rear struts below. MK1-GS23 - MOOKEEH PERFORMANCE GAS FILLED REAR STRUTS - FITS 86-89 STARION WIDE BODY STARION - PRICE IS FOR BOTH DRIVER AND PASSENGER SIDE STRUTS - $119.99 http://www.starionpartsfactory.com/suspension.html
Thanks for all the replies. I don't plan on doing a group purchase.. this would be on my own. My airdam is pretty busted up so I can't send mine. Scotty mentioned that one can be purchased from Mistubushi for @ $300? Anyone have a link? If that's all they cost, why is there such a demand? Is it just a money thing? Thanks again, Jamie Banfield Coal Valley, Il 61240 309-234-five684 87' Starion So Far: Purchased Wiper Cowl from LEPORE Purchased Pitman & Idler arm from maxboost87 I purchased my Starion on ebay from Florida for $2900 and had it shipped to Illinois. The Car is in shop right now... installing 4 struts, strut mounts, pitman & idler arms, tie rod ends.
Hi Guys - I contacted a company in India that said they can create Air Dams if I give them one to model from. Has anyone ever attempted this before? If I do have some made, what are some things we'd like to see?....such as flexibility. What would you be willing to pay for one of these? Thanks, J
I couldn't find them on eBay. How about a little help. Thanks
