MommasQuest
Everything posted by MommasQuest
Shelby....you have been very helpful. I did what you said and I have pulse from the inj plugs and 12 v on the resistor. HMMMM! IDK! If I touch the inj itself with the 6v batt they fire with no problem and if I spray fluid in the TB I can get it to run as long as I want to spray it. There is power and pulse to the clips and there is fire to the injectors....WHY WON"T THEY WORK TOGETHER!!???!!! I appreciate all of you so much! I am learning alot. I just wanna drive my car :confused0024:
Thanks. I printed this off and I am going to check these things. I will let you know. I appreciate it.
Yes my gauge reads 40 on the fuel pressure tester. If I touch the injectors with a 6V battery, they spray like crazy. The problem is the power going to the injectors. I just not sure how to fix it.
Thanks Shelby. I cleaned the connectors and still have nothing. Do you think the ballast resistor has anything to do with it? I am frustrated. She runs like a top as long as you spray starting fluid in the TB. I have spray when I connect a 9v to the injectors. I checked the connectors and they have power. I am sooo close I can see the horizon! Any thoughts? Thanks so much!
Ok...I do not have pulse to my injectors. Now what? Can anyone help me out with this?
Thanks. I checked the TPS and it was correct, haven't checked the CTS yet. I will try it. I picked up a loaner Noid light kit and the PFI for GM didn't really fit and I couldn't get a reading. I am ordering the Bosch PFI Noid and will see if that is the problem.
Thanks! Where is the link?
Hey guys! Can anyone tell me how to test the ECU on this car? I have a 1989 Conquest. Thanks.
I am working on my 89 Quest....have been for about a month now. I have narrowed things down, but need some help. How do I check the injector plugs? And can anyone tell me how to check my ECU to ensure that it is working properly? Thanks.
OK...I'm back!!! I don't know what to do with this car! We have replaced the fuel pump, cap, rotor, pick up, plugs, wires, fuel filters, MAF, ignitor box, valve cover gasket (just needed it), exhaust gasket and turbo gasket. NO loose vacuum lines and plenty of gas from the injectors. WHEW! I love the car, but it is beginning to be a money pit and if I can't get it running soon, I may just have to move on to something else...it's DEPRESSING! It starts and runs for about 10 seconds and dies. I am at a loss. PLEASE HELP!
Can I change from a stock wastegate actuator to a single port? I am a new Conquest owner and I think I blew my actuator. Not sure how to go about replacing it.
How much for the wastegate actuator?
Do you have a wastegate actuator? If so how much and can you ship it?
Yeah, weak battery. I looked all around the throttle body and didn't see anything disconnected. What does the "ovcp" look like?
Yes, the tach bounces when trying to start.
I need the adjuster bolt for the pulley on the compressor. There are two of them, one with a hole in the head and the one that goes into the hole in the head. Got one? Hit me up. Thanks!
OK everyone....now we have fire on all four cylinders and the coil. The engine turns over, but WILL NOT start. The injectors are spraying great. IDK.
i have strong fire at the coil but weak at the plugs .coil fired at ground but not at center of dist
not realy now it wont run and has weak spark at the plug but strong at the coil .coil fires hard to a ground but not to distheld coil wire close to center of cap no fire
Good point....haven't checked the intercooler for that. I heard a loud pop like popping a brown paper bag. Something blew off somewhere. It is alot louder on the exhaust than it was before the incident. I appreciate all the post. Thanks.
I already checked the timing and she is "dead on" The link you provided is very useful. I will try that as well. Thanks.
No bounce in the tach....checked the ohms on the coil...all good.
Hey! I am new to this forum and have just purchased my 89 Conquest. Glad to be part of the family, unfortunately, I see being part of the family also has it's price...LOL. MY CAR WON'T START! I was driving and went to pass someone. I dropped to 4th gear and went to pass, when I did, the car made a loud noise like popping a paper bag then lost all power. I tried to pop the clutch and it would not start back up. After getting towed to the house, it finally tried to run, but would only stay running if I patted the gas. Replaced the rotor, cap, plugs and fuel pump. There is no water in the oil and the compression is 140 in all cylinders. Car is in TIME and have spark at the coil but not at the plugs...???? What am I missing?!?!?!?! Checked the ignition module and it is in the correct OHMS range. However cannot get the stator to spark when checked with a screwdriver. If there is anyone that can help me with this matter, please, please, please send all advice it will be greatly appreciated!!!! Help the newbie get back on the road. :deadhorse:
