Jayton
Everything posted by Jayton
Very Nice '87 TSi 5 Speed, Red/Black, Upstate SC $6500
Jayton replied to theastronaut's topic in Cars for sale
Curious why the engine bay is black? Was this an originally black car that has been resprayed red or was the engine bay sprayed black when the engine was out of the car at some point? -
South Florida Performance tubular exhaust manifold
Jayton replied to DianaKJ's topic in Parts for sale
My SFP header cracked after only a few hundred miles on it and it didn't come with a guarantee so I was SOL. -
Anyone have a good solution for repairing the 2 side tabs that are supposed to hold the plastic bezel/trim in place that's located under the seatbelt release levers? I would prefer not to glue it in place because I would like for it to remain removable. I'm hoping someone has devised a way to make a replacement clip of some sort? The metal clips at the top where it meets with the lid of the center console storage compartment are fine. It's the 2 side clips that were part of the plastic that have snapped off. Any and all input or suggestions for solutions are appreciated.
Random parts for sale - NEW/USED/OEM/AFTERMARKET/PERFORMANCE
Jayton replied to SFBMX88's topic in Parts for sale
Is this still available?- 39 replies
- oil filter relocation adapter
- injector resistors
- (and 3 more)
Understood regarding readings at the + terminal on the injector clips not being fully accurate and good to know. We have been somewhat skeptical about this so thank you for confirming. Actual readings at the injector + pin were just under 12volts at like 11.8 and 11.9 respectively. We will need to directly measure the resistance as you have described to be certain. I do have a spare resistor pack that can be used. Is there a way to bench test it? Also are new OEM units still available if needed? A quick visual inspection last weekend didn't show anything to be concerned about in terms of corrosion on the contacts, but I agree that these should be thoroughly examined and proved good. Thank you for suggesting. OK. I have been assuming that the coolant temp sensor has been working because the dash gauge has been reading accurately (I now realize that these are 2 different sensors :/ ) Judging by the color of the brass on it, it appears that the CTS that's currently installed is an older piece and so we will need to test this for sure. Should I be getting an OEM unit if it proves to be faulty (and are they still available) or are the aftermarket sensors OK?
OK, is 45psi what has been determined by most to be the optimal baseline fuel pressure with the aftermarket 650/950 combo? I don't quite understand what switching to a larger secondary would do or tell us if the problem still persists? If the injector is not coming on what difference will a different size injector make? And are you offering to lend me the 1050 you have for testing purposes? If so I appreciate it and will let you know if we get to the point that it seems necessary to swap it out. Agreed. I completely trust the quality of work that has been performed, but it never hurts to recheck things. Especially when certain parts are as old as they are. Agreed on the airflow signal and actually am thinking we should start here. And to confirm my understanding, without the correct signal in hz (390 on / 290 off) as you described earlier, the ECU will not activate/terminate the secondary correct? Am I asking for trouble (in the form of future issues) by continuing to rely on the used TPS's that are available? I just hate the notion of using unreliable old parts that could potentially fail prematurely. I have read the positive reviews on the Mazda TPS conversion kit that is being offered by another member here http://www.starquest...pic=136410&st=0 and wouldn't mind splurging on a brand new Mazda TPS if it means longer term reliability. Understood. So essentially, if we can get the airflow table created properly in eManage to provide the correct airflow signal to the ECU in hz then the MAS can be eliminated and the MAP sensor can be used in its place.
Great information. I truly appreciate all of it. I'm just tying to absorb it all to determine the most logical plan of attack to try and pinpoint the root of the issue. If you don't mind me asking, what would your approach be in terms of the order in which you would test things? For example; Would you start by switching back to the MAS and checking the hz signal the ECU is or is not seeing or start with something like the TPS? I'm just trying to be as logical as possible about things by going after the most probable causes first and working my way down from there. While I'm comprehending all of the information that has been offered so far I'm still unclear as to which of it points to the most probable cause given what I've described and what has already been tested. My concern with switching back to the MAS is that the problem existed prior to switching to the MAP sensor and so it would seem that the issue is independent of the change. It's also my understanding that airflow is not metered with a MAP sensor, but then there must be an alternate method within the eManage to be able to provide the ECU with the signal it needs to drive the secondary injector? If the eManage was capable of driving low impedance injectors then I could just relieve the ECU of this responsibility, but from what I have been told it can only drive high impedance injectors.
TPS & ISC were checked prior to the original tuning when the poor running condition originally started. The TPS checked out fine. A broken wire was found on the ISC and repaired to test out good. Given their age, however, I know I can't rule out the possibility that either one of these parts could have gone bad since then and so I will need to re-test each. Also wanted to mention that the vacuum advance checked out good, but the mechanical advance has not been checked. From what I have read in other posts, this could cause timing issues that could cause the symptoms I'm having? So just to clarify, if the distributor is not able to advance the timing does this effect the secondary injector from firing or coming on when it's supposed to or does it simply cause the engine to run poorly and to break up badly? I'm not 100% clear on the correlation between the engine timing and the secondary injector if there is one? So, if I understand correctly, what you're saying is that the air flow meter and TPS are largely in charge of when the secondary injector comes on and that it may not come on at all if the signal from either of these sensors is not being read properly by the ECU? So if I go back to the MAS (which is easy enough to do) and I'm able to read the airflow signal from it in hz with the eManage and the secondary is not coming on at 390 hz and going of at 290 hz like it's supposed to, what will this confirm?
I hope I didn't confuse you. To clarify, it's rock solid at 40 psi while revving the engine in neutral without any load on the motor. Not while driving the car and with the engine under a load. Otherwise, are you saying that I should be able to build boost and see fuel pressure adjust in neutral? If you would please clarify I would appreciate it because as far as I understand this is not possible. However, if what you're saying is that I should be building boost by 2500 RPM with the engine under load while driving and that the fuel pressure should be rising 1:1 accordingly I understand and agree that it should, but unfortunately cannot verify this at this time because the car is barely drive-able.
Due to how poorly it runs over 2500 RPM's, I haven't been able to drive it enough or been able to get it into boost under load to be able to truthfully answer that. All testing and diagnostics we have performed thus far have been with the car in neutral in my driveway and with no load on it or the ability to build boost in neutral the fuel pressure has remained rock solid at 40psi (which is what I have it set at) even when it starts breaking up.
Yes the car is an '87 (with 88/89 ECU). I have the Trilogy RRFPR that mounts in the stock location to control pressure. For monitoring fuel pressure I have a 1 1/2" fuel pressure gauge mounted on the TB as well as a cockpit mounted gauge. I don't have any way to monitor the fuel pressure via the eManage (that I am aware of) if that's what your mean when you ask if it's 'loggable'.
OK thanks. So given that information, are there any additional signal paths that should be checked to this effect that we have not covered already? Or have I potentially disturbed any of these signals with the mods that have been made? Also, is there any way to read or diagnose what the ECU is seeing in terms of these signals? What's still the most puzzling to me is that the car was running real strong prior to being shipped and nothing was changed or altered between here and there. Having now performed the diagnostics as listed in my original post I'm simply at a loss for what else could have caused the secondary injector to stop firing between here and there. I understand that certain parts are 25+ years old at this point and can go bad at any point, but it seems that we have confirmed that the known causes for this condition are all sound and in working order. Finally, the injectors are from Fuel Injector Clinic (650cc Primary / 950cc Secondary found here: http://fuelinjectorclinic.com/starion-conquest/IS6595). Has anyone had known problems with injectors from this vendor or with this cc combo? I don't believe the injector to be dead due to the pigtail swap test we performed, but can't rule out that it may be faulty to some effect. I'm confident that the the injector connections and wiring are all in good order as per the tests we've performed.
Sorry for the long post in advance, but I’ve read through all posts pertaining to the secondary injector not firing and have covered all probable causes I could find in all of the previous posts to no avail. So here’s my situation that I’m hoping you guys can help me figure out: First My Engine Mods: - Block was boiled, balanced, blueprinted and bored .30 over and deck was milled - Crankshaft was index ground, micro-polished and all oil holes were chamfered for increased flow - Balance shafts are eliminated - Connecting rods were race prepped - shot peened, beam polished, resized on the big ends, small ends bushed for floaters, new rod bolts installed, magnafluxed and balanced. - JE forged pistons with Total Seal rings. - ARP hardware was used where applicable in the re-assembly. - An Ajusa head gasket with ARP head studs. - A new M6 non-jet valve head - ported and polished with a 3-angle valve job on stainless steel valves with performance valve retainers, keepers, springs and a stock cam. - A custom tubular, equal length header w/ external wastegate mount - A Mitsubishi TD05 - 20G 'Frankenstein Stage 4' turbocharger - HKS 40mm external wastegate - HKS EVC IV. - HKS blow off valve - Custom mandrel bent intercooler piping and OVCP - Intake manifold match ported - Throttle body enlarged to 52mm - Crane Cams Hi-6 ignition amplifier - Magnecor 10mm wires - Custom 2 ½" downpipe and straight through exhaust. - Custom Griffin 3-row aluminum radiator - Bosch Hi-Performance fuel pump with all new stainless fuel lines. The car had been running great and I sent it to my good friends performance shop where he sorted out all of the final punch-list nonsense that remained after a complete ground-up restoration/modification process that I performed off and on over the course of the past 15 years or so. The sorting out the car needed had nothing to do with the way it ran, but more with the annoyances of stuff like no power steering, tachometer not working, suspension noises, no heat and the like. He was able to successfully complete everything on my list and everything seemed to be great until suddenly, out of nowhere, the car just started running like complete crap. After checking through all of the basics we believed that possibly one or both of the injectors were clogged or going bad (I was still running the 25 year old OEM units at that time) and so I had the injectors and several other pairs I had lying around sent out for cleaning/repair and all were deemed as unrepairable. Left with no other option we purchased and installed aftermarket Delphi units using a 650 Primary with 950 Secondary, but the problem persisted and even got worse. Knowing how the TBI does not always react favorably to aftermarket injectors I decided that we should try to tune the car using the Greddy eManage Ultimate engine management system that I had installed years before, but had never actually used. The car had run great prior to this situation and so the eManage had yet to be needed. I had originally installed the eManage with the purpose of one day fine tuning the car on a dyno for optimal A/F ratio. So we had the car street tuned in NY by a reputable tuner during which it was driven approximately 20-30 miles in different heat cycles and varied loads with no problems. The car ran strong with the only issue being that the boost level was not able to be limited by the HKS EVC IV (later found a melted plastic T-fitting on the silicone hoses running to/from the external wastegate which has since been replaced with a brass fitting). After the tune the car was run another 7 – 10 times and ran like a champ every time. With everything in good order I had the car shipped to NC (where I recently relocated to) in an enclosed 18-wheel car transporter. After receiving the car in NC I took it out for a test drive and it did not run good at all. It was falling flat on its face at about 3000 rpms so I limped it back home and ran it in the driveway for a while. In my driveway the car idled perfectly, all temps and pressures were good and solid, but romping on the gas would cause it to break up bad. However, by gently giving it gas I was able to get it to rev past 3000 RPM’s and into the 4000 – 5500 range and hold it there with only very minor sputtering. I tried to drive it a few more times and nothing changed and I was at a loss because it had been running great in NY right before being loaded on the trailer so I don’t know what could have gone wrong between here and there. Since tuning had proven to be successful in solving the running issues we experienced in NY I located a mechanic/tuner here n NC who came out to my home this past Sunday to try to sort things out via the eManage. I had heard about cars ‘losing their tune’ unexpectedly with the eManage and so figured it was a good place to start. Here is what transpired: We began to tune the car using the eManage Ultimate software and the wideband O2 sensor (located in the downpipe). The tuning went well, holding 14.2-14.6 AFR up until about 2400 RPM, where any changes made did not have any effect at all and the engine continued to severely stutter, acting as if fuel starvation or REV cut was occurring. We then removed the MAS and replaced with a MAS unit I modified/hacked to retain only the Air Intake Temperature (AIT) sensor in the stock location. We then switched to the Greddy MAP sensor by connecting a vacuum line to it from the #4 port on the intake manifold. (I had pre-installed the MAP sensor with this intent when originally installing the eManage years prior). We then made the necessary changes in eManage to read the MAP sensor accordingly. The theory behind the switch to the MAP sensor was that with no way to really test the MAS and no good replacements units available, I’d rather do away with it altogether than to play a guessing game with whether or not it was operating properly. Not to mention the additional airflow gained from removing all that clutter from the air intake path. The car did not run any better after the switch and the car idled oddly, wanting to die at times when warm. After some diagnostics and consulting by phone with the previous tuner, we determined that the secondary injector was not pulsing and so we performed the following tests to try and determine why: 1. Swapped Primary injector pigtail to the Secondary to confirm that the Secondary injector does in fact work; Confirmed Working. 2. Checked continuity from ECU through eManage harness; Confirmed Good. 3. Checked continuity through OEM harness to new injector pigtails; Confirmed Good. 4. Checked continuity from either ECU pin crossing to either harness pin; Confirmed Good (but suspect bad injector resistor) 5. Diagnostic on injector resistor revealed 12v on single post in both connectors; Confirmed Good, however, we are still suspect of this. Is this truly a solid test of the resistor? Could there still be something wrong with it even though it passes this test? I believe I have another one laying around I can swap in just to be sure. Are these resistors still available new OEM or aftermarket? 6. Swapped ECU with a spare to confirm that the injector driver in the ECU was not faulty. Problem persisted and so I’m assuming the ECU drivers are good, but I still have other spare ECU’s that can be swapped in just to be certian. 7. Removed custom eManage harness from between factory harness and ECU and plugged the factory harness directly into ECU. The car ran poorly (as to be expected because MAS was removed in favor of the MAP sensor) and problem persisted. 8. Injectors Ohms: @ Primary: 2.7 @ Secondary: 2.5 Compensation for the injectors within the eManage does nothing because it will not recognize or drive low impedance injectors and so they are still being driven by the stock ECU. Any help on something we have missed in the injector driver path? Any additional sensors that trigger the secondary injector? From what I understand the injectors are driven via RPM signal into the ECU? Could the aftermarket ignition system, the tach sensor for it or the actual factory tachometer wiring be a culprit here? I was unable to get the tachometer to work with the Crane Cams Hi-6 through the wiring harness and so a jumper wire was installed on the circuit board on the back of the cluster to give it its signal. You can respond here or contact me directly at jtilt25@yahoo.com Thanks in advance to all for reading my lengthy post and for any advice or clues you might be willing to offer.
It was actually nerve racking to drive on Long Island. I just didn't enjoy driving it there at all. It is WAY too crowded, everyone drives up your tail and the road conditions are absolutely horrible. It was so stressful that I just kept the car locked up in the Garage all the time. I'm hoping I'll finally be able to enjoy it here in NC.
Yes indeed. I moved to Raleigh NC this past January otherwise I'd love to meet up.
Thanks Randy! Yes sir. I don't ever intend on selling it. #1 I'm still a Starion enthusiast through and through and #2 I don't think I'd ever find anyone who would be willing to pay anywhere near what I've got into it.
Updated link: http://www.26liter.us/?p=401
I would think that specs would be available from HKS or from HPF who is selling them.
Anyone ever run these HKS injectors in their car? http://www.horsepowerfreaks.com/partdetails/HKS/Fuel/Fuel_Injectors/-/1912 I know the general consensus is that these cars runs best with the stock injectors but just curious if these are a more viable option than the other aftermarket options since they are from such a company like HKS
It may seem that way, but that guy is asking about running his car without the power steering belt because he doesn;t wanna fix whatever problem he's having. I'm asking for feedback from anyone who has actually done the proper conversion to manual steering that I will most likely do. I'm looking to find out how easily the car steers with manual gearbox as compared to power steering. Also looking for feedback on the difficulty of the conversion.
I'm interested in converting to a manual gearbox because I hate all the excess hoses, fluid, components, leaks etc. I'm just looking for some feedback from anyone who has converted. Thanks.
Definitely checked the pickup tube. Ran it in the parts washer and all. So the relief valve opens at a certian oil pressure to keep it from rising to much. Then if it were stuck open there would be crappy pressure at idle and lower RPM's, but not bad enough to do damage?
Yes, I pulled the pump apart and checked the gears and housing. Everything looks OK. I'll try packing the gears to see what happens. Believe you me, I certianly will not be able to ever use this car with any confidence unless something is discovered as the definitive cause. I'm hoping it's the same culprit that has been causing my turbo lubrication problems as I have never been able to pinpoint that one either.
Although the oil pump checked out fine on the bench, I put it back on the car along with the oil pan and when spun with an air ratchet the pump produces no oil flow. Could the relief valve be stuck? Either way I'm gonna put a new pump on it. It never ends.
