socal
Website URL
http://japanesenostalgiccar.com/
1213 profile views
Burabuda's Achievements
anybody else want to join in? i'm being outnumbered by haters! http://bringatrailer.com/2015/10/15/turbo-seatbelts-1987-mitsubishi-starion-esi-r/#comments worst is the 944 guy
Street Neo Classics 80s and 90s Car Show (Torrance,CA)
Burabuda replied to zafalla's topic in StarQuest Meet Planner
I'll be there -
thx guys & sorry for the late reply! it's running dual mikunis with the thin intake that only has 1 vacuum port
Torque Specs for NA Exhaust Manifold & DP Flange?
Burabuda replied to Burabuda's topic in Virtual Mechanic
ok then a better question would be "do i need to use a torque wrench in this situation?" and the answer seems to be "no" -
looked in my repair manual but couldn't find. guessing 25ftlbs for manifold & 35ftlbs for dp flange?
well i don't remember if it was leaking because i limped it home and parked it a few years ago i do know there wasn't a gasket on there when i pulled it apart (i know that could mean squat) i'm about ready for 1st startup and want to be proactive..
there was no gasket between the mani & dp. i see a slight gap tho. should there be one? http://i39.tinypic.com/scw6qa.jpg something like this? http://i41.tinypic.com/2im5jld.jpg'' or this? http://i44.tinypic.com/2lddfo9.jpg
pcv to brake booster T ... got it rear port w/light spring check valve ... then what?
So there's 2 vents on the valve cover. Where would you advise that I route these on an engine that's running an aftermarket carb & intake and no conventional air cleaner btw the intake only has a provision for the brake booster and the heater
^ this deal fell thru anybody else got one fs? (as in original post, plz pm thx)
in good cond. no holes or bad corrosion be willing to ship pm thx http://i46.tinypic.com/js0x8h.jpg
hi all, having already sealed the oil pan up on g54b and installed the oil pickup tube with paper gasket i've discovered the starquest parts locator shows a separate o-ring in addition to the paper gasket should remove the sealed oil pan to install this o-ring? http://www.starquestgarage.com/partsloc/conquest/1988/88_conquest_partsloc_nav.html 9a 3600
either the "L" shape starquest or any other g54b style that isn't completely rusty. tia!
