I just brought the car in the garage and put it up on the lift. It is all stock as far as I can tell. The brake leak is from the master cylinder, which has caused a lot of paint to wrinkle on the driver side frame rail but certainly ok for repaint if the motor was out. The passenger frame rail is rusted but not bad, a little welding and it will be fine. It is an SHP car with 6 bolt axleshafts. The outer boots need to be replaced. I think the alternator is bad because it won't run unless I keep the jumper cables on it.
