apedog Posted November 13, 2009 Report Share Posted November 13, 2009 (edited) ok so i havent really been bothered by it but it DEFF noticeable. Usually it sound like what i call the inside of an airplane noise.Now its so loud that you actually have to raise your voice a little to talk to people in the car. Question is, is my fuel pump going out? Thanks ps NOT a stock fuel pump i think its a bosch or wahlboro? idk the guy i bought it from said its not stock Edited November 13, 2009 by apedog Link to comment Share on other sites More sharing options...
Killtodie Posted November 13, 2009 Report Share Posted November 13, 2009 if its stock, yes. Link to comment Share on other sites More sharing options...
JDean Posted November 13, 2009 Report Share Posted November 13, 2009 One of the fuel filters could be clogged Link to comment Share on other sites More sharing options...
Killtodie Posted November 13, 2009 Report Share Posted November 13, 2009 Well, does it sound like its working overtime or a bad bearing? Eitherway, looks like you will be dropping the tank, inspecting both filters. I say get a new high flow fuel filter, replace that, install a fuel gauge if you dont have one yet, empty the tank, drop it, inspect the intank filter, replace it eitherway, check for sludge and rust, inspect the fuel pump, do a flow test, replace it if necessary, blow some oven cleaner in the fuel line, blow it out with compressed air. a good days of work. Link to comment Share on other sites More sharing options...
Shelby Posted November 13, 2009 Report Share Posted November 13, 2009 check the pump if it's a masters E2315 they do make a heck of a lot of noise sp bad i have a new one never use'd seting on the shelf my personal opinion is bosh is the best pump you can buy and quiet but thats just me , mine could run 80 psi 24/7 and hardly hear it Link to comment Share on other sites More sharing options...
apedog Posted November 13, 2009 Author Report Share Posted November 13, 2009 Well, does it sound like its working overtime or a bad bearing? Eitherway, looks like you will be dropping the tank, inspecting both filters. I say get a new high flow fuel filter, replace that, install a fuel gauge if you dont have one yet, empty the tank, drop it, inspect the intank filter, replace it eitherway, check for sludge and rust, inspect the fuel pump, do a flow test, replace it if necessary, blow some oven cleaner in the fuel line, blow it out with compressed air. a good days of work. It starts to sound like it working overtime after about 5 minutes of running.The car did sit for 3 years so I guess it was bound for something to get stuck in something Link to comment Share on other sites More sharing options...
Shelby Posted November 13, 2009 Report Share Posted November 13, 2009 restrict'd fuel to the pump will make a changes whine up and down as the pump recives fuel,this is cause'd by cavatition , fuel, no fuel , fuel etc , a pump under heavy load will have a steady high pitch'd whine check the intank and pump supply filters and lines,, to check for a worn out pump , replace the main filter up frt,, cut the old one apart and look for metal shaveings Link to comment Share on other sites More sharing options...
Shelby Posted November 13, 2009 Report Share Posted November 13, 2009 have no clue why only half that reply post'd but here goes again when the fuel is below 1/2 a tank all fuel has to enter the splash bowel thru this intake pipe,, if the car runs fine with a full tank but don't when under 1/2 a tank of fuel this could be the problem trash in the metal intake pipe http://26liter.us/gallery/albums/userpics/10009/fuel_tank_baffles.jpg Link to comment Share on other sites More sharing options...
apedog Posted November 13, 2009 Author Report Share Posted November 13, 2009 restrict'd fuel to the pump will make a changes whine up and down as the pump recives fuel,this is cause'd by cavatition , fuel, no fuel , fuel etc , a pump under heavy load will have a steady high pitch'd whine check the intank and pump supply filters and lines,, to check for a worn out pump , replace the main filter up frt,, cut the old one apart and look for metal shaveings thats exactly what it does and Shelby which one is the intake pipe I have never seen the inside of the gas tank Link to comment Share on other sites More sharing options...
Shelby Posted November 13, 2009 Report Share Posted November 13, 2009 that pipe that goes arround the bowel, is the fuel inlet and only fuel nlet when the fuel level drops below 1/2 a tank in the pic your looking from bottom of the tank up up Link to comment Share on other sites More sharing options...
apedog Posted November 13, 2009 Author Report Share Posted November 13, 2009 that pipe that goes arround the bowel, is the fuel inlet and only fuel nlet when the fuel level drops below 1/2 a tank in the pic your looking from bottom of the tank up up oh ok thanks Link to comment Share on other sites More sharing options...
bld127 Posted November 16, 2009 Report Share Posted November 16, 2009 The pump I put on it when the stock one died was the Masters E2315 to get more flow. Pump always did make a little noise. Pump has a lifetime warranty if you want a new one. Let me know.Brett Link to comment Share on other sites More sharing options...
apedog Posted November 16, 2009 Author Report Share Posted November 16, 2009 (edited) I put this stuff called Chem 12 (its like sea foam) in the gas tank and it must of cleared whatever was blocking what because its back to normal sounding. Edited November 16, 2009 by apedog Link to comment Share on other sites More sharing options...
Killtodie Posted November 16, 2009 Report Share Posted November 16, 2009 It can comeback, there must be contamination in your tank. I would still drop it and look inside and replace the filters Link to comment Share on other sites More sharing options...
bld127 Posted November 17, 2009 Report Share Posted November 17, 2009 The car had only been driven about 700 miles in the last 6 or 7 years, and a lot of the time I had it, it sat with only a couple gallons of fuel in it. Tank should probably be dropped and fully cleaned out.Brett Link to comment Share on other sites More sharing options...
