losisonq Posted October 19, 2009 Report Share Posted October 19, 2009 Is it possible to use the stock power antenna with an aftermarket radio? I know most new head units use a blue wire for 12v out to the antenna but our cars antenna relay requires more than just 1 wire to operate. Is there a work-around or interface to allow it to work with just the one 12v signal wire? Thanks in advance. Link to comment Share on other sites More sharing options...
on4now4 Posted October 19, 2009 Report Share Posted October 19, 2009 i just put a toggle switch in so that i can put it up and down manualy. i cant remember which wire it is but u just connect it to a power source and it auto goes up all the way and when u cut the power it goes down. works nice Link to comment Share on other sites More sharing options...
DryBear Posted October 20, 2009 Report Share Posted October 20, 2009 I replaced my broken antenna with a Metra universal motorized antenna, and just bypassed the antenna relay by wiring directly into the relay harness (unplugged from the relay). Link to comment Share on other sites More sharing options...
Tman Posted October 20, 2009 Report Share Posted October 20, 2009 i have a jvs double din and have no issues with stock antenna works like it should Link to comment Share on other sites More sharing options...
Jms Posted November 4, 2009 Report Share Posted November 4, 2009 Is it possible to use the stock power antenna with an aftermarket radio? I know most new head units use a blue wire for 12v out to the antenna but our cars antenna relay requires more than just 1 wire to operate. Is there a work-around or interface to allow it to work with just the one 12v signal wire? Thanks in advance. Hi, Since no one really answered your question, hopefully you have found the answer by now. If not, here is the info that you were looking for: Yes, an aftermarket radio will work with the OEM power antenna. To do so, wire the Blue wire on most aftermarket radios to the White/Black wire found on the smallest of the three stock radio connectors. I'd recommend buying an adapter in order to mate the two harnesses, avoiding cutting the stock harness. Rgds,Jms Link to comment Share on other sites More sharing options...
mikec Posted November 11, 2009 Report Share Posted November 11, 2009 Yes, an aftermarket radio will work with the OEM power antenna. To do so, wire the Blue wire on most aftermarket radios to the White/Black wire found on the smallest of the three stock radio connectors. For 87-later setups at least, I don't know about the earlier model year cars: The physically smallest connector? That'd be the steering wheels control input; it doesn't have a white/black wire. It does have the fewest number of wires though (4). The smaller of the two connectors at the bottom of the stereo (the two "main connectors") has the correct white/black wire for the power antenna; it should be near the center of the 5 wires on this connector. mike c. p.s. the steering wheel controls connector looks larger on the factory service manual schematic diagrams... rather misleading. It's a small connector, about half an inch by half an inch. The smaller main connector with the power antenna wire is about half an inch by an inch in size. Link to comment Share on other sites More sharing options...
Jms Posted November 13, 2009 Report Share Posted November 13, 2009 p.s. the steering wheel controls connector looks larger on the factory service manual schematic diagrams... rather misleading. It's a small connector, about half an inch by half an inch. The smaller main connector with the power antenna wire is about half an inch by an inch in size. I agree with you. Thanks for the correction. Rgds,Jms Link to comment Share on other sites More sharing options...
