xxx87quest24psi Posted August 11, 2009 Report Share Posted August 11, 2009 (edited) I have a 87 conquest with a 4g63 swap started for sale, This car is a mint Arizona car No rust...! Need's a new front bumper, air dam and rear bumper that's it..! Otherwise this car is straight and clean, the clear coat is peeling a little bit and could use paint.. It even has good tire's. But now for the good part.. I started the 4G swap it is in the car and mounted to the stock Conquest tran's...!!! I made a tran's adapter plate.. It's a 91 6 bolt motor with 80,000 mile's RAN awesome. I have a Garret TO4 turbo for it oil feed only.. The intake is flipped to work and rewelded, I've got the 4G wiring harness and most of he other part's to finish it. All you'll need is injector's, clutch, timing belt, other small odd's and end's plus an ECU to get it running.. This is my second 4G63T swap i've done ran outta money on this one haha... This is a steal most of the hard work is already done, you just need to bolt some thing's on.... If interested please call me at 815 291 4122 my name's Aaron Im posting a bunch of picture's a little later $800 obo Edited September 22, 2009 by xxx87quest24psi Quote Link to comment Share on other sites More sharing options...
Jdubya Posted August 11, 2009 Report Share Posted August 11, 2009 I have a 87 conquest with a 4g63 swap started for sale, This car is a mint Arizona car No rust...! Need's a new front bumper, air dam and rear bumper that's it..! Otherwise this car is straight and clean, the clear coat is peeling a little bit and could use paint.. It even has good tire's. But now for the good part.. I started the 4G swap it is in the car and mounted to the stock Conquest tran's...!!! I made a tran's adapter plate.. It's a 91 6 bolt motor with 80,000 mile's RAN awesome. I have a Garret TO4 turbo for it oil feed only.. The intake is flipped to work and rewelded, I've got the 4G wiring harness and most of he other part's to finish it. All you'll need is injector's, clutch, timing belt, other small odd's and end's plus an ECU to get it running.. This is my second 4G63T swap i've done ran outta money on this one haha... This is a steal most of the hard work is already done, you just need to bolt some thing's on.... If interested please call me at 815 291 4122 my name's Aaron Im posting a bunch of picture's a little later 1500 obo Wish you were closer I would buy it NOW. I can source the parts for my 4g swap for what you're asking for the whole car! Quote Link to comment Share on other sites More sharing options...
Constant_project21 Posted August 13, 2009 Report Share Posted August 13, 2009 Texted! Quote Link to comment Share on other sites More sharing options...
xxx87quest24psi Posted September 22, 2009 Author Report Share Posted September 22, 2009 <!--quoteo(post=931911:date=Aug 11 2009, 12:39 PM:name=xxx87quest24psi)--><div class='quotetop'>QUOTE (xxx87quest24psi @ Aug 11 2009, 12:39 PM) <a href="index.php?act=findpost&pid=931911"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->I have a 87 conquest with a 4g63 swap started for sale, This car is a mint Arizona car No rust...! Need's a new front bumper, air dam and rear bumper that's it..! Otherwise this car is straight and clean, the clear coat is peeling a little bit and could use paint.. It even has good tire's. But now for the good part.. I started the 4G swap it is in the car and mounted to the stock Conquest tran's...!!! I made a tran's adapter plate.. It's a 91 6 bolt motor with 80,000 mile's RAN awesome. I have a Garret TO4 turbo for it oil feed only.. The intake is flipped to work and rewelded, I've got the 4G wiring harness and most of he other part's to finish it. All you'll need is injector's, clutch, timing belt, other small odd's and end's plus an ECU to get it running.. This is my second 4G63T swap i've done ran outta money on this one haha... This is a steal most of the hard work is already done, you just need to bolt some thing's on.... If interested please call me at 815 291 4122 my name's Aaron Im posting a bunch of picture's a little later 1500 obo<!--QuoteEnd--></div><!--QuoteEEnd--> Wish you were closer I would buy it NOW. I can source the parts for my 4g swap for what you're asking for the whole car! Quote Link to comment Share on other sites More sharing options...
xxx87quest24psi Posted September 22, 2009 Author Report Share Posted September 22, 2009 I would be willing to deliver the car for the cost of fuel plus a little... I would like to get 800 hundred for the entire thing, all part's included and half a car's worth of body part's and glass Quote Link to comment Share on other sites More sharing options...
xxx87quest24psi Posted September 22, 2009 Author Report Share Posted September 22, 2009 New price check out my new post I have a 87 conquest with a 4g63 swap started for sale, This car is a mint Arizona car No rust...! Need's a new front bumper, air dam and rear bumper that's it..! Otherwise this car is straight and clean, the clear coat is peeling a little bit and could use paint.. It even has good tire's. But now for the good part.. I started the 4G swap it is in the car and mounted to the stock Conquest tran's...!!! I made a tran's adapter plate.. It's a 91 6 bolt motor with 80,000 mile's RAN awesome. I have a Garret TO4 turbo for it oil feed only.. The intake is flipped to work and rewelded, I've got the 4G wiring harness and most of he other part's to finish it. All you'll need is injector's, clutch, timing belt, other small odd's and end's plus an ECU to get it running.. This is my second 4G63T swap i've done ran outta money on this one haha... This is a steal most of the hard work is already done, you just need to bolt some thing's on.... If interested please call me at 815 291 4122 my name's Aaron Im posting a bunch of picture's a little later $800 obo Quote Link to comment Share on other sites More sharing options...
quikconq Posted September 22, 2009 Report Share Posted September 22, 2009 so the location is arizona??????? Quote Link to comment Share on other sites More sharing options...
acidbath Posted September 29, 2009 Report Share Posted September 29, 2009 Please post pics of it. Quote Link to comment Share on other sites More sharing options...
smallblock12 Posted October 4, 2009 Report Share Posted October 4, 2009 how much for the motor??? very interested Quote Link to comment Share on other sites More sharing options...
bmx152 Posted October 15, 2009 Report Share Posted October 15, 2009 where are you located? Quote Link to comment Share on other sites More sharing options...
AndyW Posted October 15, 2009 Report Share Posted October 15, 2009 Zip code says Freeport Ill. sounds like a decent deal for a rust free straight body too. Quote Link to comment Share on other sites More sharing options...
bmx152 Posted October 15, 2009 Report Share Posted October 15, 2009 what state is he in cause i dont want to message him if hes in arizona and im in long islnad ny cuz id be wasting both of our time Quote Link to comment Share on other sites More sharing options...
