StarionPAP Posted June 6, 2009 Report Share Posted June 6, 2009 (edited) I'm having problems. I have changed my injectors, injector clips, fuel pump, fuel filters (all of them), fuel line, etc... See my signature for mods. The car pulls fine when I just started it, pulls all the way to redline, keeps boost up, but once the car gets hot (operating temperature), I get a stutter, hesitation @ around 4000 rpm. I know it good be bad quality fuel, but I put premium, and even add octane boost. I checked my Vac advance and it is working fine. Could it be the TPS?? Any helps would be appreciated. StarionPAP Haiti Edited June 6, 2009 by StarionPAP Link to comment Share on other sites More sharing options...
Cybion Posted June 6, 2009 Report Share Posted June 6, 2009 I can't promise that this is your problem but my cousin has much the same problem with her Dodge Stealth. She did everything you named and still had the problem. In the end it turned out that her car didn't like gas with ethanol in it, she started putting in gas that had less ethanol in it and it runs perfectly. Oddly enough it was always 4K too. As I said, I'm not positive, but maybe. Link to comment Share on other sites More sharing options...
StarionPAP Posted June 6, 2009 Author Report Share Posted June 6, 2009 I checked my Vac advance, it's not keeping vaccum. Will need to change it. I got exposed copper at the TPS, will need to change that too. Hope after that, she holds boost all the way to WOT. Link to comment Share on other sites More sharing options...
89PalermoSHP Posted June 8, 2009 Report Share Posted June 8, 2009 http://www.starquestclub.com/forum/index.php?showtopic=29597. THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM THIS IS NOT A Q/A FORUM Link to comment Share on other sites More sharing options...
StarionPAP Posted June 8, 2009 Author Report Share Posted June 8, 2009 Oops! Sorry, wrong forum. Won't happen again. StarionPAP Haiti Link to comment Share on other sites More sharing options...
89PalermoSHP Posted June 9, 2009 Report Share Posted June 9, 2009 it just keeps the clutter out so next time you have a question you can check here and skip right to the answer Link to comment Share on other sites More sharing options...
