CARZSASYJ Posted November 27, 2008 Report Share Posted November 27, 2008 does anyone kno where to get a new oilcooler Quote Link to comment Share on other sites More sharing options...
jolyrgr Posted November 27, 2008 Report Share Posted November 27, 2008 I could prob find a few good clean used ones. Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted November 27, 2008 Report Share Posted November 27, 2008 I'm sure I've got an OEM and probably one aftermarket cooler too if you need one. Quote Link to comment Share on other sites More sharing options...
CARZSASYJ Posted November 28, 2008 Author Report Share Posted November 28, 2008 i spun multi bearings and im replaceing anything that oil pasted thru to make sure all the work i had done is not going to die the first time i crank the cooler needs to work with "brians" aftermarket line and be super clean Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted November 28, 2008 Report Share Posted November 28, 2008 The coolers I'll have will not have had any trash run through them. One is an OEM, set up for stock lines. Not sure if Brian's lines will bolt to them. The other is a universal, the hoses slip over the tubes and clamp with hose clamps. Quote Link to comment Share on other sites More sharing options...
