scooterh72 Posted September 1, 2008 Report Share Posted September 1, 2008 (edited) I am looking for the ignition key cylinder on the column with keys and matching door locks. OK, I had a key made from the code from the door lock and it does not work for the ignition. Must have been changed at some point (it was in the glove box so who knows). So does anyone have the ignition cylinder and key they can part with? Thanks. Scott Edited September 3, 2008 by scooterh72 Quote Link to comment Share on other sites More sharing options...
chasm2530 Posted September 1, 2008 Report Share Posted September 1, 2008 http://cgi.ebay.com/ebaymotors/1987-Conque...d=p4506.c0.m245 This guy says he has the whole car and will take e-mails for other parts. Is your switch worn out or do you just not have the key? If you just need the key you can pull the passenger-side door lock cylinder-it has a code that a key-shop can make a key from. Quote Link to comment Share on other sites More sharing options...
scooterh72 Posted September 1, 2008 Author Report Share Posted September 1, 2008 http://cgi.ebay.com/ebaymotors/1987-Conque...d=p4506.c0.m245 This guy says he has the whole car and will take e-mails for other parts. Is your switch worn out or do you just not have the key? If you just need the key you can pull the passenger-side door lock cylinder-it has a code that a key-shop can make a key from. I just bought another car (was intended for parts but might restore) and I do not have a key. Didn't know about the code on the door lock. Thanks for your help!! Much appreciated Quote Link to comment Share on other sites More sharing options...
Lives4Speed Posted September 1, 2008 Report Share Posted September 1, 2008 If it's a Starion, Mitsubishi has records of the codes by VIN Number. They can cut one for you too. SQC member Bad2Rass may be able to help you out. L4S Quote Link to comment Share on other sites More sharing options...
scooterh72 Posted September 1, 2008 Author Report Share Posted September 1, 2008 If it's a Starion, Mitsubishi has records of the codes by VIN Number. They can cut one for you too. SQC member Bad2Rass may be able to help you out. L4S Its a conquest Quote Link to comment Share on other sites More sharing options...
scooterh72 Posted September 3, 2008 Author Report Share Posted September 3, 2008 (edited) Its a conquest Updated my original request Edited September 3, 2008 by scooterh72 Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted September 3, 2008 Report Share Posted September 3, 2008 Just pull your switch and have it rekeyed to match your door locks. Any good locksmith can do it, probably around $30. Quote Link to comment Share on other sites More sharing options...
scooterh72 Posted September 3, 2008 Author Report Share Posted September 3, 2008 Just pull your switch and have it rekeyed to match your door locks. Any good locksmith can do it, probably around $30. Thats where I am headed today, to the lock and key shop to see what they can do. Thanks for everyone's help. Quote Link to comment Share on other sites More sharing options...
