8starion7 Posted August 8, 2008 Report Share Posted August 8, 2008 i just picked up an 87 starion and its only running about 7-8 psi. what is the stock psi on these cars? Link to comment Share on other sites More sharing options...
Aesop Posted August 8, 2008 Report Share Posted August 8, 2008 Roughly 7.5psi for your model year. Link to comment Share on other sites More sharing options...
8starion7 Posted August 9, 2008 Author Report Share Posted August 9, 2008 ok. i was told by the previous owner that he had it at like 12psi but its 100% stock. Link to comment Share on other sites More sharing options...
jlnelson51 Posted August 12, 2008 Report Share Posted August 12, 2008 he probebley had a manual boost contorller that he took off before you boght it, they are able to do 12psi for the stock turbo, but i would go to a exguhst system, 2.5'' or 3'' and a blow off valve, then go to 12psi with a boost controller Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted August 13, 2008 Report Share Posted August 13, 2008 Not that anyone without experience should do it, but i've seen the stock setup go to 21psi.. Heavy exhaust manifold/turbo porting etc... If the fuel and ignition system is working fine, and of course the motor has good compression and passes a leak down test, 15psi will be fine for most people with an exhaust. It's pointless to do this with the stock exhaust. Link to comment Share on other sites More sharing options...
8starion7 Posted August 14, 2008 Author Report Share Posted August 14, 2008 (edited) i think that the guy was just talking out of his a**. cuz it was surging around 6 psi when i bought it and i got home and found tons of open tees. i just got a muffler and am doing a custom 3" from turbo back. then looking at getting hardpipes and a bov. Edited August 14, 2008 by 8starion7 Link to comment Share on other sites More sharing options...
8starion7 Posted August 17, 2008 Author Report Share Posted August 17, 2008 not sure what the car should vac at too. i had found tons of boost leaks and not sure if there is anymore. so where should the vac be. car is all stock. Link to comment Share on other sites More sharing options...
Shelby Posted August 18, 2008 Report Share Posted August 18, 2008 normal vac for a engine in good condition 19-21 inches 2" vacuum gauges are not super acurate Link to comment Share on other sites More sharing options...
