3.80 gear in rear
this was from a recent post thread
this is from SQClub
thanks to emagdnim
hope he don't mind us copying it
Montero with leaf springs: 83-87: Varies from year to year on what trucks got what.
4.625 = MB185463
4.875 = MB527147
4.222 = MB185462
Montero 3.0 with coil suspension: 89-91: all years one option.
4.625 = MB598210
Montero 3.0: 92-96: varies in different options for all years
4.625 = MB598210
4.875 = MB598487
4.636 = MR162750
Montero 3.5 DOHC: 94-00:
4.636 = MR124857
4.272 = MR296349
Montero 3.5 SOHC V6 24V: 01-02
Can't pull information up on this one yet.
Montero 3.5 SOHC V6 24V: 03
Montero Sport: 2.4: 2WD: 96-99: only one option for these years.
4.222 = MB185462
Montero Sport: 3.0: 2WD: 97-03:
4.222 = MR162749
4.636 = MR162750
4.900 = MR296348
Montero Sport: 3.5: 2WD: 99-03
4.272 = MR296349
4.636 = MR124857
Montero Sport: 3.0: 4WD: 97-03
Wont let you select the gears.
Montero Sport: 3.5: 4WD: 99-03
4.272 = MR296349
4.636 = MR124857
4.900 = MR124858
Mighty Max: 2.0: SWB/2WD: 87-89: only one option.
3.909 = MB185461
Mighty Max:: 2.6: SWB/2WD: 87-89: only one option.
3.545 = MB185460
Mighty Max: 2.4: SWB/2WD: 90-96 only one option.
3.909 = MB185461
Mighty Max: 2.6: LWB/2WD: 87-89
3.545 = MB185460
4.222 = MB185462
Mighty Max: 2.4 LWB/2WD: 90-95
4.222 = MB185462
3.909 = MB185461
Mighty Max: 2.6 LWB/4WD: 87-89
3.909 = MB185461
4.222 = MB185462
Mighty Max: 3.0 SWB/4WD: 90-95
4.222 = MB527248
3.909 = MB185461
4.222 = MB185462
Mighty Max: 3.0 LWB/4WD: 90-91
4.222 = MB527248
_________________
Shelby
emagdnim
Posted: Fri May 23, 2008 12:24 am
Yea, i made that one up for everone over there.
I can get you a 4.20 gearset "kit" that includes the seals, bearings, and gears for $600 plus shipping. Brand new OEM parts.
I just put one together for another member.
this is from SQClub
thanks to emagdnim
4.625 = MB185463
4.875 = MB527147
4.222 = MB185462
4.625 = MB598210
4.625 = MB598210
4.875 = MB598487
4.636 = MR162750
4.636 = MR124857
4.272 = MR296349
4.222 = MB185462
4.222 = MR162749
4.636 = MR162750
4.900 = MR296348
4.272 = MR296349
4.636 = MR124857
4.272 = MR296349
4.636 = MR124857
4.900 = MR124858
3.909 = MB185461
3.545 = MB185460
3.909 = MB185461
3.545 = MB185460
4.222 = MB185462
4.222 = MB185462
3.909 = MB185461
3.909 = MB185461
4.222 = MB185462
4.222 = MB527248
3.909 = MB185461
4.222 = MB185462
4.222 = MB527248
_________________
Shelby
emagdnim
cool take for info
so this 3.90 and 4.20 is better then stock in what way.
i have friend with a mustang just v6 but he charged out is rear diff gear and drop a hole sec on his time.
what type of gear or switch one will do this>?
that funnyyyyy , i when i on the hwy at 70 mph i am at 3500 rpm, those that mean i already got one
or the person i bout the car from already swap it over
i have 87???????????
Manuals and automatics have a different overdrive ratio... so no. ;)
Do you also own a Honda?
Tack or speedo could be off. Best way to check ratio is jack up car with trans in neutral. Rotate rear wheels one revolution, with lsd they should turn together. If drive shaft turns 3.54 times it's a 3.54. 3.9 times its a 3.90. Do it a couple of times. It's enough of a difference between the two that it"s pretty easy to tell this way.
