drifter87 Posted May 17, 2008 Report Share Posted May 17, 2008 (edited) Ok, as some of you may know, I have a new engine and turbo in my starion. It ran great for a week and now it's showing some problems. On start up it idles fine with intermittent misses.When it's warm and idleing it's stumbles real rough and dies occasionally. When I accelerate it backfires in small pops and seems to handle the boost alright. When I let off the pedal I can smell gas but it doesn't backfire until around 1500rpms. I wondering if it could be a problem with the vacuum and/or possibly running rich? I can smell gas like i'm inside the tank. The injectors are new trilogy turbo and I jus found the wires of one of the clips were exposed to each other so I wrapped em up. Edited May 24, 2008 by drifter87 Link to comment Share on other sites More sharing options...
Alcyone Posted May 19, 2008 Report Share Posted May 19, 2008 update? did fixing the injector wires clear up the problem? Link to comment Share on other sites More sharing options...
drifter87 Posted May 24, 2008 Author Report Share Posted May 24, 2008 No. It still ran rough and died. I couldn't hear any hissing for a vacuum leak, though I will be getting down and dirty with the car this week sometime to see if any of the vac lines are cracked or disconnected. Link to comment Share on other sites More sharing options...
jolyrgr Posted May 25, 2008 Report Share Posted May 25, 2008 As info.....I got word back from "Trilogy Turbos" regarding the flow rating. His injectors were flow rated at 43.5psi. Stock regulator setting is 37-38psi. A little more pressure might make a big difference for some of you that use these and have issues the swap. JR Link to comment Share on other sites More sharing options...
Indiana Posted May 25, 2008 Report Share Posted May 25, 2008 you should have just cleaned your stock injectors Link to comment Share on other sites More sharing options...
