KeithTSI Posted December 1, 2004 Report Share Posted December 1, 2004 hey, got a brake leak, but there never any fluid on the ground....any suggestions? i have to fill the resevoir every coupld days, and the brakes are spongy... Link to comment Share on other sites More sharing options...
jr_ss Posted December 2, 2004 Report Share Posted December 2, 2004 I'd check a caliper.... Gotta be coming out somewhere. If there are no puddles, look for gooey spots around the brakes, that could give a hint to which one it is... It could also be leaking out the back of the mastercylinder into your brakebooster... Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted December 2, 2004 Report Share Posted December 2, 2004 If it is leaking behind the booster, it will seep down into the steering coupler and trash it.. Brake fluid will eat away your bushings, believe that.. Like Jr said, it has to be coming from somewhere.. If you can't find it, clean all related parts and brake area's.. Refill the fluid and drive around, come back and check for the new leak(s)... Link to comment Share on other sites More sharing options...
860QuestTuner Posted December 5, 2004 Report Share Posted December 5, 2004 yeah,make sure you check all parts to the brake system,hoses too.Try haveing someone pump the brakes with the car off and look all over for anyleaks,make sure it's clean first. Link to comment Share on other sites More sharing options...
KeithTSI Posted December 5, 2004 Author Report Share Posted December 5, 2004 the steering coupler...is that the part that keep the play out of your steering wheel? mines got a s*** load of play....i checked all my front end part and there really no play in anything, so im thinking its whatever that rubber bushing is. Link to comment Share on other sites More sharing options...
860QuestTuner Posted December 6, 2004 Report Share Posted December 6, 2004 It's like a universal joint in between the steering box and the fire wall,It's part of the colum,look under the master cylinder,you'll see it. Be safe bad brakes could be a bad thing when you need to stop.ya dig. Link to comment Share on other sites More sharing options...
KeithTSI Posted December 6, 2004 Author Report Share Posted December 6, 2004 ya i hear ya, i got the engine pulled right now so i tryng to get this figured out befoe i get it going again...hopefully ill find something today. Link to comment Share on other sites More sharing options...
