Zer0fist Posted January 10, 2003 Report Share Posted January 10, 2003 Any body running a 1G DSM "AWD" with an Eibach Pro Kit? Was wondering if it needs a camber kit, Â or can i go without? Link to comment Share on other sites More sharing options...
Zer0fist Posted January 20, 2003 Author Report Share Posted January 20, 2003 :-* gee, thanks guys... Link to comment Share on other sites More sharing options...
Quest4Power Posted January 20, 2003 Report Share Posted January 20, 2003 best place to ask would be a DSM board... just a suggestion Link to comment Share on other sites More sharing options...
Zer0fist Posted January 21, 2003 Author Report Share Posted January 21, 2003 HAHA1 ya gotch'a, will do. Just thought there were some DSM'rs on this site, from reading some of the posts around here. Link to comment Share on other sites More sharing options...
dfowler21 Posted January 24, 2003 Report Share Posted January 24, 2003 Im running Prokits on my 1g AWD without a camber kit. Its just a tiny bit out of spec. Nothing Im concerned with. As long as I can get the toe correct and the camber is symetrical all is well. I dont have any unusual tire wear problems from it. Link to comment Share on other sites More sharing options...
jonesh242 Posted February 4, 2003 Report Share Posted February 4, 2003 I also have a 1g tsi AWD w/ eibach pro kit and AGX (front) and koni(rear). Its a little off, but nothing to be concerned about. You should, however, make sure you change out your struts for better ones when you switch the springs. good luck. john Link to comment Share on other sites More sharing options...
Guest lazynothin Posted March 24, 2003 Report Share Posted March 24, 2003 You WILL need a camber kit. Plus you will have to modify the rear lower control arms in order to obtain the camber range you will want. Most suggest cutting about 1/8 of an inch and weld 'em back up. Though I will agree with Superquest_T61, you'll have more replies on dsmtuners.com or dsmtalk.com for this question. Link to comment Share on other sites More sharing options...
